quigonjay Posted September 11, 2008 Share Posted September 11, 2008 hi, having a little trouble getting a relacement strut for a j-spec tt are they not available from toyota? it has tokico struts, are these the oem ones for a j-spec? tried ordering one from toyota with the model number on the car and they assure me the the one they sent is the correct one it obviously isnt as it is a bilstein and the spring platform sits approc 5mm higher i'm assuming the bilsteins where on uk cars? if not available from toyota where can i get a replacement tokico strut? thanks Jay Quote Link to comment Share on other sites More sharing options...
georigg Posted September 12, 2008 Share Posted September 12, 2008 Do search on KYB suspension units. I posted a contact telephone number about 6-7 months ago for a UK supplier for KYB which was the OEM supplier to Toyota in Japan. The other possibility of course is that someone has fitted after-market struts in which case you will likely have to fit two new ones.........which is always the best thing to do anyway when renewing suspension shocks/struts anyway. Rgds George Quote Link to comment Share on other sites More sharing options...
Paul372 Posted September 12, 2008 Share Posted September 12, 2008 just fit two new bilsteins best to replace them in pairs anyway Quote Link to comment Share on other sites More sharing options...
AdzC Posted September 12, 2008 Share Posted September 12, 2008 The Bilsteins were an option on the Supra as my SZ has them. Might be as well renewing all four. Nic can get hold of them for a decent price, see here Quote Link to comment Share on other sites More sharing options...
quigonjay Posted September 12, 2008 Author Share Posted September 12, 2008 Do search on KYB suspension units. I posted a contact telephone number about 6-7 months ago for a UK supplier for KYB which was the OEM supplier to Toyota in Japan. The other possibility of course is that someone has fitted after-market struts in which case you will likely have to fit two new ones.........which is always the best thing to do anyway when renewing suspension shocks/struts anyway. Rgds George how strange, the tokico items definately look oem as they also have toyota branding on them? Jay Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted September 12, 2008 Share Posted September 12, 2008 If you have yellow shocks does that mean they're the bilsteins? are the bilsteins stiffer? Quote Link to comment Share on other sites More sharing options...
AdzC Posted September 12, 2008 Share Posted September 12, 2008 If you have yellow shocks does that mean they're the bilsteins? are the bilsteins stiffer? They are yellow but should laso have the Billstein logo on them. I believe they are stiffer than the OEM dampers. Quote Link to comment Share on other sites More sharing options...
quigonjay Posted September 19, 2008 Author Share Posted September 19, 2008 this is the strut i was reffering to, part number doesnt exist according to toyota would this have been the oem struts in japan then? cheers jay Quote Link to comment Share on other sites More sharing options...
Nic Posted September 20, 2008 Share Posted September 20, 2008 this is the strut i was reffering to, part number doesnt exist according to toyota would this have been the oem struts in japan then? I can't find the part number either, the first part 48530 is the correct number for the damper, the second part I cannot find reference too. As mentioned earlier I would replace both sides at the same time. Quote Link to comment Share on other sites More sharing options...
Nic Posted September 20, 2008 Share Posted September 20, 2008 If you have yellow shocks does that mean they're the bilsteins? are the bilsteins stiffer? Mostly likely they are, here is a pic of the OEM Bilsteins. They are slightly stiffer. http://img215.imageshack.us/img215/1017/cimg00037nc.jpg Quote Link to comment Share on other sites More sharing options...
