jlgee80 Posted September 11, 2008 Share Posted September 11, 2008 Gents, Just wondering if there is anyone local to derbyshire/midlands that could install a clutch for me for a fair price of course Car is a 94 Jspec N/a. It's recently started slipping in 4th/5th under the most load. Looking underneath (best i can there appears to be some oil from somewhere, cant be quite sure if this has made it onto the clutch tho). I would attempt the fix myself but no time and no location (terraced street)! Any help would be much appreciated. Regards, Jason. Quote Link to comment Share on other sites More sharing options...
little num Posted September 12, 2008 Share Posted September 12, 2008 hi m8 if the oil is coming from the hole in the gearbox at the bottom then most likely to be your rear crank seal, these are £50 from toyota (tt one) maybe cheaper for none turbo. As for fitting me and my brother could fit the new clutch in his garage as we did my uk tt clutch last week, and bought all the tools needed, price fitted £150 if you need a rear crank seal then add £25, will take all day so might want to leave it with us. Quote Link to comment Share on other sites More sharing options...
bignum Posted September 12, 2008 Share Posted September 12, 2008 Err na`s arent as easy as ours kid, the clutch neads lining up iirc, Quote Link to comment Share on other sites More sharing options...
jlgee80 Posted October 9, 2008 Author Share Posted October 9, 2008 All sorted gents.....thanks for the replies The esteemed mr Wilson performed the install!! Quote Link to comment Share on other sites More sharing options...
