Quite Urgent for MOT!
Markie
Hi all,
I have done the fog conversion today.. However, as the dash is still off, I was wondering if anyone knows how the fog switch/wires/lights works on the right hand stick for the front fogs? As instead of using a switch for the rear which works fine, I would like to hook them up so that when the switch is turned on, on the stick it lights up both the front and rear fog lights..
Had a look and with my trustly multimeter, did not have any luck..
Any info on this would be excellent..
Best Regards,
Marcus.
you can just take the feed from the front fog lamp connecter, run it through a relay and hey presto. :looney: but don't forget to wire in a telltale light in dash for rear fog.
How can I find the feed to the front fog, its all in the main light I thought (HID)
Do you need a light on the dash for the fog aswell. I am sure I dont have one for the front ones.
yes its in the main lamp unit .but the outer one is your foglight. switch fogs on, remove cover on rear of lamp and see which colour wire feeds that bulb.
as for your telltale front fogs are not part of the mot test, its the rear only and you will require to wire a lamp that illuminates when rear fogs are on.
