Pimped Prius
michael
http://www.autobloggreen.com/2008/08/18/video-customized-prius-proves-that-hybrids-and-common-sense-do/
It's often been said that just because you can it doesn't mean you should. Automotive customizers frequently go well beyond the bounds of good taste and common sense. Fortunately, the Toyota Prius has not been frequently included in these aesthetic misadventures. A Swedish customizer has now seen fit to to correct this oversight by applying just about every modification know to man to one innocent Prius. Apparently the powertrain is the only thing left untouched. With all the extra mass this beasty surely carries, this Prius no doubt makes the standard model look like a speed demon. It also makes a stock Prius look gorgeous by comparison. I'm not sure what else there is to say about this travesty but you can check out the video after the jump... if you dare!
AH8kHOW4gAI
