Loss of boost.
chris2o2
:rolleyes: Not again i hear you say !
But wait , i'm just after someone to confirm my suspicions that it is just a small leak somewhere and nothing more sinister.
The cars making about 0.4 on first turbo then 0.5 on the second , im sure last month i had noticed it was down slightly although not as low as it is now. The car still feels quite strong and accelerates well , just a bit slower really.
I had a friend take this small video of my boost gauge to double check this - foot flat down through third ....
Most of the pipes you can see in the engine bay are new although the ones hidden are still original , so there may be some worn/damage ones back there i need to check . IC piping maybe ? The BOV seems pretty good , i tried the standard toyota one again this afternoon to see if that made a difference but no. Any other suggestions ?
Cheers
Most likely VSV problem. Had somewhat similar problem too. Just to sort it out and get my car running I ditched the sequential operation and did a TTC mod. Slightly laggier but power's great plus the supposed long-term reliability benefit for the turbos is always welcome. :)
Yes check ALL of your VSV's and vacuum hoses. Also check to see if you have any boost leaks. Do not ditch the sequential system. TTC creates a ton of lag and makes no more power. It was meant to be used as a diagnostics tool. It has also never been proben to be any more reliable to the turbos.
Just take your time and go over everything. Most likely there is a vacuum line or something simple that has come off.
