Adam Kindness Posted August 25, 2002 Share Posted August 25, 2002 If my turbos are gone i'll be needing some new ones, or one. Im after some options! Replace them with hybrids? Replace them with a single? Is it right that i'll have to upgrade the fuel system if i go for anything other than the stock OE items? ( i was hitting around 18psi anyway) Could some one give me a list of 'needs' etc etc (and prices if poss) Bigger injectors Fuel Rail ECU or somesort of fuel controller Turbo(s) FMIC Quote Link to comment Share on other sites More sharing options...
Adam Kindness Posted August 25, 2002 Author Share Posted August 25, 2002 up we go Quote Link to comment Share on other sites More sharing options...
Gareth Davies Posted August 25, 2002 Share Posted August 25, 2002 Adam, there's a fair amount of insight into this in the 500+Nos thread. Hybrids really need injectors / resistors / fuel comp but you can run without them (really depends on their size), big singles really require bigger than UK injectors and a decent FMIC but can make far more horses - at the higher end you're well into built engine territory. Which of course isn't cheap. Hybrids are about £1500 the pair + 350 for the injectors (UK used) and £300ish for the fuel comp. Singles are £3000+ about £500 for decent injectors and the same for a fuel computer... but you could really do with a uprated ECU, £1000 ish for the AEM if you're feeling lucky and £LOTS for a fitted motec. Quote Link to comment Share on other sites More sharing options...
Adam Kindness Posted August 26, 2002 Author Share Posted August 26, 2002 cheers Looks like i'll be going for a pair of mild hybrids then.... the upgrading the fuel system Quote Link to comment Share on other sites More sharing options...
