123tom123tom Posted September 7, 2008 Share Posted September 7, 2008 :(right i finally got the supra started for the first time in about 4 month, as some of you know i have been doing a steady single project. To be fair it still isn't complete but i was at a stage where i could start it. My problem is that when i started it, it kicked out lots of blue smoke and then carried on smoking but not as bad as the start up, the thing is it didnt do this before i was going single so could it be the fact it hasnt been started in months. Also the car doesnt run very well, but i put this obviously down to the ecu not beeen mapped yet/no intercooler fitted yet. any one know what the above could be, any input is appreciated Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 7, 2008 Share Posted September 7, 2008 (edited) Difficult to say for sure, it could of had a bit of oil sitting in the cylinders and then it whent on to draw from worn guide seals, i am presuming its a new turbo? what make? could be residual oil in that, burning off, otherwise i would say the turbo oil seals. Edited September 7, 2008 by Tricky-Ricky (see edit history) Link to comment Share on other sites More sharing options...
123tom123tom Posted September 7, 2008 Author Share Posted September 7, 2008 Difficult to say for sure, it could of had a bit of oil sitting in the cylinders and then when on to draw from worn guide seals, i am presuming its a new turbo? what make? could be residual oil in that, burning off, otherwise i would say the turbo oil seals. how would i check the above statements in regards to turbo residue/seals etc:) Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 7, 2008 Share Posted September 7, 2008 I would have thought a bit of a drive would see any residual oil that sitting anywhere would be dispersed, is the turbo new? it could be seeping a little due to high vacuum at idle/low RPM until the seals bed in. Link to comment Share on other sites More sharing options...
