Not De-misting?
Tricky-Ricky
Just wondered if anyone else has had this problem, its only happened about three times so far, and only in heavy rain, and i am inclined to think that its down to the air con not coping with the sudden change in temperature of the screen,
i just get sudden mist up and have to keep wiping the screen until everything catches up, which sometimes takes a few minutes, which is a bit worrying on the motorway:(
Heater matrix seems fine, this only happens with heavy rain, and i have tried the non re-cirque switch, the only way i could get it to demist was to turn everything up full, and even then it took its time, the rest of the time it seems to work as it should:blink:
Switch on your A/C (yes, despite the cold weather) and turn the temp to about 25 degrees C so you don't freeze your bits off. That will demist all interior glass very quickly.
