bolarbag Posted September 5, 2008 Share Posted September 5, 2008 What is the best most reliable pump for WI? I'm be running some methanol too, dont want to buy an aquamist kit as I'll be using the motec to control the injection, I've heard various reports that they fail aswell Adequate size jets for around 600hp? I remember seeing a company from the states that produced a reliable water/meth pump, alkali or something, can't find it Quote Link to comment Share on other sites More sharing options...
AshBhp Posted September 5, 2008 Share Posted September 5, 2008 The new AEM. http://www.aempower.com/ViewCategory.aspx?CategoryID=120 Quote Link to comment Share on other sites More sharing options...
bolarbag Posted September 5, 2008 Author Share Posted September 5, 2008 AEM stuff scares me a little, who makes their pump? Quote Link to comment Share on other sites More sharing options...
Wez Posted September 5, 2008 Share Posted September 5, 2008 Isnt it a Surflo pump like the new Aquamist setup Quote Link to comment Share on other sites More sharing options...
bolarbag Posted September 5, 2008 Author Share Posted September 5, 2008 http://www.alkycontrol.com/ Alky! Mis-spelt it, thers a fair few of them up here;) This was recommended on SF a while back, also noticed UKRich is using an aquamist 2C system controlled via his motec, I'll pm him see if its still running good How has folks aem pumps held up? Quote Link to comment Share on other sites More sharing options...
Wez Posted September 5, 2008 Share Posted September 5, 2008 Why are you going to use the MOTEC to control it? Are you going to be mapping it in, ie more boost, ignition and less fuel, if so will you also have the motec setup to detect a WI system issue, ie pump failure, blocked jet or filter etc. Just asking as most people simply use it for a little added safety, a simple pressure switch which turns it on at approx 1bar is normally enough, the cars are then mapped with the WI disabled so that if there is an issue you dont blow the motor. FYI I run a Aquamist 1s activated at 1bar with 50/50 water/meth. Quote Link to comment Share on other sites More sharing options...
bolarbag Posted September 5, 2008 Author Share Posted September 5, 2008 a WI system issue, ie pump failure, blocked jet or filter etc. More flexibility of when the water injection comes on and off, and more conditions, as well as seperate maps I can set up the pump detection failure, and pressure sensor, dont expect the jets to become blocked, Quote Link to comment Share on other sites More sharing options...
bolarbag Posted September 5, 2008 Author Share Posted September 5, 2008 FYI I run a Aquamist 1s activated at 1bar with 50/50 water/meth Have you ever recorded intake temps before the mix is added and after How many jets do you have what size and where are they positioned? Quote Link to comment Share on other sites More sharing options...
Wez Posted September 5, 2008 Share Posted September 5, 2008 Have you ever recorded intake temps before the mix is added and after Nope, I rarely download logs from my ECU, I can check when I am next out if you like. How many jets do you have what size and where are they positioned? I have a single .7mm infront of the throttle at the moment, I have a couple more jets and a small manifold so that I can try different sizing and location. Just havent got round to it yet. Quote Link to comment Share on other sites More sharing options...
bolarbag Posted September 5, 2008 Author Share Posted September 5, 2008 Yeah would be interesting to see how much of an affect it has on intake temps if any I'll have an intercooler spray and a couple of jets, pre intercooler, one after Quote Link to comment Share on other sites More sharing options...
uk-rich Posted September 5, 2008 Share Posted September 5, 2008 you don't want one pre intercooler, the mist will condense on all the fins and turn into a puddle in your fmic Quote Link to comment Share on other sites More sharing options...
bolarbag Posted September 5, 2008 Author Share Posted September 5, 2008 Rules that out then:d How is your aquamist holding up, still going strong? Quote Link to comment Share on other sites More sharing options...
uk-rich Posted September 5, 2008 Share Posted September 5, 2008 absolutly no probs at all, i have the motec contol the injection via the high speed valve als have the DDS3 to monitor the flow, not like i'd dare to look down at the gauge when on the peddle Quote Link to comment Share on other sites More sharing options...
Milton79 Posted September 5, 2008 Share Posted September 5, 2008 http://www.aquamist.co.uk aquamist is a good system and their pumps can be used with methanol. i havent heard of "high failure rates on them". my mate has used aquamist on his cosworth engines for the past 8 years. he uses 100% meth on a seperate container and he has moved the kit through several applications (different cosworths) in the past 8 odd years. the only thing he has changed in that time is the in-line filter and a relay (the realy got water soaked and rusted over time) recently he also purchased a new loom that comes with the dash lights to show you details of the system in use, armed, low water/meth levels. otherwise very reliable IMO Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 5, 2008 Share Posted September 5, 2008 My Aquamist setup has been on two different cars over five years with no problems, waits for immanent failure:blink: Quote Link to comment Share on other sites More sharing options...
Wez Posted September 5, 2008 Share Posted September 5, 2008 Mine has been fine for a few years. The older type pumps use to suffer with water ingress but as far as I am aware the issues were resolved long ago. Quote Link to comment Share on other sites More sharing options...
supra Posted September 6, 2008 Share Posted September 6, 2008 i know of a guy...local to me....who has a built r32 GTR running motec and aquamist for the past 3 years......WITHOUT ISSUES too... Quote Link to comment Share on other sites More sharing options...
