Guest Charlierob Posted September 4, 2008 Share Posted September 4, 2008 Please can anyone tell me what the ignition timing is on my auto N/A (ie deg. BTDC etc) and also the idle speed. Just setting up after a rebuild. Many thanks Rob Link to comment Share on other sites More sharing options...
georigg Posted September 5, 2008 Share Posted September 5, 2008 Charlie, Straight from the workshop manual; Timing 10 Deg before TDC Tick-over for 2JZ-GE 700RPM +-50RPM "JZ-GTE Link to comment Share on other sites More sharing options...
georigg Posted September 5, 2008 Share Posted September 5, 2008 Sorry hit wrong button before posting Charlie, Straight from the workshop manual; Timing 10 Deg before TDC at idle speed. Tick-over for 2JZ-GE 700RPM +-50RPM 2JZ-GTE 650RPM +- 50RPM Usually at start up of the car from cold it will rev to about 1800 RPM then drop progressively down to normal as above, in a very short period. Dont quote me but I THINK the timing is pre-set, may be others can comment on whether(or not) it is adjustable and how to do it. George Link to comment Share on other sites More sharing options...
Guest Charlierob Posted September 5, 2008 Share Posted September 5, 2008 Thank you very much. Rob Link to comment Share on other sites More sharing options...
