ignition timing and idle speed
Guest Charlierob
Guest Charlierob
Please can anyone tell me what the ignition timing is on my auto N/A (ie deg. BTDC etc) and also the idle speed. Just setting up after a rebuild.
Many thanks
Rob
Sorry hit wrong button before posting
Charlie,
Straight from the workshop manual;
Timing 10 Deg before TDC at idle speed.
Tick-over for 2JZ-GE 700RPM +-50RPM
2JZ-GTE 650RPM +- 50RPM
Usually at start up of the car from cold it will rev to about 1800 RPM then drop progressively down to normal as above, in a very short period.
Dont quote me but I THINK the timing is pre-set, may be others can comment on whether(or not) it is adjustable and how to do it.
George
