Guest brad26-supra Posted September 4, 2008 Share Posted September 4, 2008 when i start my n/a from cold and drive it straight away the rear of the car judders and i can hear knocking.it doesnt happen all the time, its pretty much irregular but unsure if its oil on the clutch, damaged clutch and flywheel or something else.has anyone got any idea what it might be. Quote Link to comment Share on other sites More sharing options...
georigg Posted September 5, 2008 Share Posted September 5, 2008 Brad, If it happens AS you drive away, during lifting your foot off the clutch then it could be associated with the clutch, however if it occurs after engaging the drive, i.e foot off clutch and accelerating, it could also be one of the U/J joints either at the prop shaft or on one of the half shafts...............replacing a U/J is relatively easy if you know what your doing!.......about £10 to buy each and about an hour labour if someone else does it. Rgds, George Quote Link to comment Share on other sites More sharing options...
Guest brad26-supra Posted September 7, 2008 Share Posted September 7, 2008 Thanx george,greatly appreciated Quote Link to comment Share on other sites More sharing options...
