Stan Posted September 4, 2008 Share Posted September 4, 2008 Right, I'm being a complete idiot here, but I don't know a lot about turbo cars and don't want to be messing anything up! I've got my Supra with the Blitz SBC-ID III fitted in the car already. There is already a blue pipe from the engine bay into the cabin which the unit it T-pieced into, this reads the boost pressure I assume since that part of the unit works fine Now, the solenoid unit is already installed in the engine bay... but I have no idea which pipes to connect up/disconnect/block off etc, and the fitting instructions I've found don't really make it any easier. What I really need is someone to either post pics of what pipes go where, or I'd like some detailed instructions as to what to do when installing. Please help! Kthnx Quote Link to comment Share on other sites More sharing options...
Nic Posted September 4, 2008 Share Posted September 4, 2008 http://www.blitz-performance.com/includes/templates/2007/Manuals/SBC%20i-D.pdf Quote Link to comment Share on other sites More sharing options...
Stan Posted September 5, 2008 Author Share Posted September 5, 2008 Thanks Nic, I think I had seen you post that up before but wasn't really understanding the instructions! I can't tell whether I should be following the instructions for the single turboactuator or twin turbo actuator (I think I read you treat it as single), also do I put it on the 1st or 2nd turbo? If someone could confirm that all I need to do is cut the pipe between the compressor and actuator, then use those pipes to go to my solenoid box, I'll be happy! Quote Link to comment Share on other sites More sharing options...
