Slight hesitation on acceleration
rick001
Thanks mate, i did read this prior to selection but did not see any referance to FMIC on stock so went for the basic TT plugs - the old ones were BKR6EP11 which i take are stock ones - would you suggest any that would suit?
cheers
I noticed you have a FMIC and I just wondered if you had any other mods. If so, then you would need different plugs, otherwise I would think you should be ok.
Decats?
Have you got a boost gauge (other than the standard one)?
I would check the gaps as well.
