Benzsupra Posted September 4, 2008 Share Posted September 4, 2008 Hello everyone, My air con was working fine until i removed the dash to change the dials then i get all the right things/noises happening but no cold air. I have put this in another thread but since then i have just learned how to do a heater diagnostic test and the light above the fresh air button flashes which according to the list is the pressure switch circuit. Firstly could i have caused this but disconnecting the battery and removing the dash and secondly does anybody know what i can do to check/fix this. Thanks, Ben Quote Link to comment Share on other sites More sharing options...
rick001 Posted September 4, 2008 Share Posted September 4, 2008 Not too sure on this but when i recently removed my dash (umteenth time)i found that if you do not re-connect the connector blocks onto the heater switches correctly and firmly etc they will flash and go off and maybe you just have a bad connection - perhaps remove the dash panels and re-check all the connectors are pushed firmly home, hope this helps Quote Link to comment Share on other sites More sharing options...
Benzsupra Posted September 4, 2008 Author Share Posted September 4, 2008 Thanks for the suggestion but i already tried this when i realized it wasn't working. There's so many wires and connectors behind there i did give as many as i could a good push and wiggle Quote Link to comment Share on other sites More sharing options...
Benzsupra Posted September 6, 2008 Author Share Posted September 6, 2008 UPDATE After doing the test the compressor no longer kick in or anything... Re-gas i think with dye, maybe a leak somewhere. Quote Link to comment Share on other sites More sharing options...
