Simple Excel and VB code help please....
AlexJames
Hey guys... for all you excel gurus out there...
I need some simple code but i seem to remember some of the code is written slightly different when using vb in excel instead of vb stand alone.
I need something simple like ...
If c2.value = "***" then msgbox ("correct")
or
If c2.value = "***" then D11.value = "something else"
I know that in excel If statments will work when I code them against a command button but the .value field is obviously not correct... am I making sense? :blink:
That's right, but the syntax is like this:
If Sheets("Sheet1").Range("C2").Value = "yes" Then ....
Basically, the code drills down through the layers of an Excel spreadsheet: first it specifies the sheet, then the cell in that sheet. If you want to go wild, you can specify the spreadsheet itself if you've got more than one open (only do this if you need to: it's pointless otherwise).
