bright 1 Posted September 3, 2008 Share Posted September 3, 2008 Thinks me cats on its way out , Question ? how much do they cost and is it a easy job to do yourself. Quote Link to comment Share on other sites More sharing options...
merckx Posted September 3, 2008 Share Posted September 3, 2008 Which one? The first one is more difficult to do than the second only because you'll need a longish extention on the socket in order to reach the nuts and there's also a possibility that you could shear off a stud, so you need to be prepared for that. If you don't want to do it yourself you should be able to get it fitted at an exhaust fitting garage for a small fee. I'm sure someone will have a secondhand to sell you, I wouldn't even bother pricing a new one as it'll be very expensive. Quote Link to comment Share on other sites More sharing options...
bright 1 Posted September 3, 2008 Author Share Posted September 3, 2008 Thanks for info, not sure which one just noticed a nasty rattle sounds at front, have not had chance to get under car yet. Quote Link to comment Share on other sites More sharing options...
merckx Posted September 3, 2008 Share Posted September 3, 2008 There's a few heat shields, it could be one of those. Quote Link to comment Share on other sites More sharing options...
bright 1 Posted September 3, 2008 Author Share Posted September 3, 2008 Cheers Quote Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted September 3, 2008 Share Posted September 3, 2008 My bets on the heat shields , i've had this problem , is it auto or manual Quote Link to comment Share on other sites More sharing options...
gordy07 Posted September 3, 2008 Share Posted September 3, 2008 Heat shield sounds suspect but if its the cat you could always take it off and put a cat replacement pipe on instead Quote Link to comment Share on other sites More sharing options...
bright 1 Posted September 4, 2008 Author Share Posted September 4, 2008 Thanks all ,will check this weekend (6 speed) Quote Link to comment Share on other sites More sharing options...
michael Posted September 4, 2008 Share Posted September 4, 2008 Thinks me cats on its way out Are you a pirate? Quote Link to comment Share on other sites More sharing options...
mr lover Posted September 4, 2008 Share Posted September 4, 2008 Quote Link to comment Share on other sites More sharing options...
