Wireless problem - need WPA-PSK passphrase??
Conrad
No it's an old router, it was me that set it up.
It has a wired and wireless connection already on it. I'm trying to add another wireless connection but it's asking for my WPA passphrase.
I guess I would have created one when I set the router up but that was over a year ago and I've no clue what it is. Is there anyway i can access the router via the connections already attached and view the passphrase?
Or perhaps remove security altogether (I have no neighbors so security isn't a must)
what kind of router is it? can you log onto the router itself?
It's a Livebox from orange, you can log onto the router but you need some kind of ip address to input into your browser IIRC.
I guess I'll have to ring orange Tech Support, I was hoping to avoid them overseas muppets if I could. Plus they charge premium rate for tech support! :rolleyes:
Dude google it ffs...guaranteed it'll be on the net somewhere.
something like 192.168.0.1 or similar.
Guest gzaerojon
don't forget you can plug your pc straight into your router with a network cable to avoid the wep key, then check what ip address it gives you (start/run type cmd the in the command box type ipconfig) use the gateway address on tinternet explorer to get into your router, but you will need the login and password, it could be a standard one you can find on google or it may even be stamped on the router
http://192.168.1.1
username:admin
password:admin
(from http://zxon.notnet.co.uk/orange)
