Anyone using an XBOX as a media center?
MrRalphMan
Shameless bump....
Wow, looks like for ~£50 quid from Ebay you get everything to softmod and setup xbmc to allow streaming of movies to your telly.
Looks like the Xbox (Classic) can also send a HD picture..
Sounds great
How does it send a HD pic? You got a link?
Am interested given I have 2 limited edition green ones we never use in the house.
Example - here
Also here
You just need to go into the dashboard and let it know what options you can send.. It them chooses that optimal (Not so sure myself) picture type to display. I assume that the xbmc replacement dashboard has the same options.
That's not outputting in HD though, that's just a cable to connect it via component to a HDTV. Still only standard def.
Shameless bump....
Sounds great
Don't need to spend £50...
I've got a 98p copy of Tom Clancy's Splinter Cell, plus something called SID (which is an easy softmode installer). simply install XBMC then. It isn't a difficult operation. I've done 10 xboxs so far. Got 5 around the house as media players using an SMB connection to my NAS. They play AVI's just fine. Wouldn't bother with HD though as the processor really isn't up for the job.
All you really need is an old controller which you cut the cable and attach a normal usb connector to. Then use a small 32mb usb stick to upload the mod.
To upload apps, it is simply a case of FTP'ing the programs up to the xbox.
any good websites that go through the procedure step by step.
Also - the HDD that the XBOX classic supports / are they SATA or EIDE?
No idea on website...
The HDD's are EIDE, you can't upgrade the HDD easily with a softmod, because the xbox locks the drive. There are ways around it, but really not worth the ago. Hence the reason for using a NAS/SAN on the other side.
Once I get a console and the bits, after a bit of practise on mine, I'd be quite happy to give this a go.
[repost]Anyone able to copy the SID to a MU for me?[/repost]
The easiest way to do it, is to get a mem stick and get someone to format it on their modded xbox (formats it fatx) and copy sid to it (*hint*, I've got 4 that have SID on it). (There is a way to do it with Datel Action Replay which you can find on the net). I originally got SID from piratebay.
Sorry didn't read this thread all the way through fully..
£50 was for everything, including the Xbox, DVD Remote, Splinter Cell and prob the Action Replay to get SID onto the MU.
Would be nice if I could get the MU populated another way, not sure how though... :innocent:
Been reading up and installing the dash's seems pretty simple, FTP and overwrite the old version..
Cheers,
Paul.
