Homer Posted September 2, 2008 Share Posted September 2, 2008 The only two pronged plug I could find so far in that area is the ABS sensor for the front offside wheel. Although the manual is 1400 pages or so and might have missed a diagram or two Link to comment Share on other sites More sharing options...
SupraD06 Posted September 2, 2008 Author Share Posted September 2, 2008 is there a quick way of telling if it has or not, will the ABS warning light light up when you turn the ignition or anything like that Link to comment Share on other sites More sharing options...
Homer Posted September 2, 2008 Share Posted September 2, 2008 Do you have an engine bay picture to hand? It's quite easy to identify as there's an ABS pump up near the charcoal canister. Edit - just seen it's a TT 6spd, it should be there as standard... need to take another look at the manual unless anyone else can pipe in! Where does the wiring lead to? Link to comment Share on other sites More sharing options...
SupraShaun Posted September 2, 2008 Share Posted September 2, 2008 Mine has ABS Link to comment Share on other sites More sharing options...
SupraD06 Posted September 2, 2008 Author Share Posted September 2, 2008 This is it It runs back towards the radiator and is taped to another wire that runs off somewhere else but cant see where as its to dark now Link to comment Share on other sites More sharing options...
SupraShaun Posted September 2, 2008 Share Posted September 2, 2008 Mine is plugged into a dummy plastic bit- if you see what i mean Link to comment Share on other sites More sharing options...
SupraD06 Posted September 2, 2008 Author Share Posted September 2, 2008 so your saying yours is plugged into something, rather than just hanging free, or you mean yours has had the opposite plug end put on the end to cover the connection up ( male end into female end ) sort of thing Link to comment Share on other sites More sharing options...
SupraShaun Posted September 2, 2008 Share Posted September 2, 2008 (edited) Yes its hanging down, the plug thats hanging down by the rad has the dummy plastic bit plugged on the end. Ill try and get some pics after work tomorrow. Edited September 2, 2008 by SupraShaun (see edit history) Link to comment Share on other sites More sharing options...
