Misfiring??
markybhoy86
My single has just started doing it. Only notices on boost when Im giving it some welly and sometimes sounds bad and run likes shite on start up. According to Michel Lane who built her for me it's just a dead spart plug. Im going to replace them in the next day or two and see if that helps. Grade 7 gapped to 0.7 I think it is and I should be fine again.
And by the way, my boost symtoms are like a popping sound as it flies off and a slight sort of hesitation as it pulls - it does pull none the less but not quite as smooth as I remember
Start with the coil pack clips, check they are all ok. If they are then next is plugs, if they are ok then coil packs, thats as long as its an ignition misfire of course. Try that lot first and go from there.
That's exactly the way I went about it when I had my misfire but it kept misfiring after replacing all of those parts.
I decided to remove the crank/camshaft speed sensors, visually they looked okay. Checked the resistance, I'm not sure if this alone can diagnose them as being faulty though.
Refitted these speed sensors and now the car runs perfectly with no misfires at all. :)
Did my spark plugs today and unfortunately still does the same thing. Was advised to check the coil packs so while the engine was running I undid each clip one at a time to see what it would do. The front pack stalled the car with each clip but the middle and rear packs had the car running still so hopefully it's that. I've got to check my ignitor pack too when I find someone that can help me out too.
just so the post isnt left without an answer, the car was stripped down again at the weekend, connectors, coil pack etc was all checked and fine, the car was then shimmed (supposidly it was pain in the arse) was then put back together and since then its running great. No misfiring at all anymore =) love it again lol
Glad to hear your car is running good again! Make sure your plugs are also gapped around .028" That is what most of my friends who run cams/ single turbos run.
Guest rjchavez
I installed Crower 272's on my stocker and replaced the fuel pump and performed the 12v mod. Did require a AFC NEO for tuning purposes though.
So the cams where fitted without checking the clearances?
