mikeyb10supra Posted August 31, 2008 Share Posted August 31, 2008 I seem to have developed this rather odd boost pattern and its confusing the hell out of me at the moment. I am basically running with 1st cat in place and 2nd cat remove along with a very free flowing exhaust, I was convinced the other day the I had a boost leak in one of my IC couplings as when I came on boost I was convinced is sounded different to usual. I have now sorted this and im hitting 1bar again like before. My problem is, sometimes when I kick down I get no second turbo and only make around 0.4bar or something and other times I will get the 2nd turbo and hit a strong 1 bar? Ive read this is sometimes due to a sticky IACV actuator but im not convinced as im only hitting 0.3/0.4 bar when it happens....surely it should be 0.8 ish still?? Anyone got any ideas where to start Mikey Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted August 31, 2008 Author Share Posted August 31, 2008 Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted August 31, 2008 Author Share Posted August 31, 2008 cant believe no one has had an issue like/similar this before Quote Link to comment Share on other sites More sharing options...
kaahari Posted August 31, 2008 Share Posted August 31, 2008 IACV or EGCV vsv or actuator. I had both vsv+actuator offline due pressure tank broblem and boosted 0.3-0.4 with 2nd turbo. I suggest that check iacv vsv+actuator first (very easy to check, good place on top of engine ) and then egcv vsv+actuator. Quote Link to comment Share on other sites More sharing options...
Chris and Alana Posted September 2, 2008 Share Posted September 2, 2008 I had this problem, it done my head in but it turned out to be a bust wategate vsv, £33 later and all was good Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted September 2, 2008 Author Share Posted September 2, 2008 Did yours sound a little strange when coming on boost too?? ive been out tonight and on vaccum to pressure (0.1bar ish) it sounds like its almost hissing air which points to a boost leak? Thing that confuses me is that the FMIC silicine couplings were all checked and double checked over the weekend and still this problem persists and the car still pulls well to 1bar Doing my head in now....might look into the VSV solution Quote Link to comment Share on other sites More sharing options...
Chris and Alana Posted September 3, 2008 Share Posted September 3, 2008 It didnt really make any different noises but when I put my foot down and the box dropped a gear, it should have brought tubbie 2 online but sometimes nothing, just a poor 4psi (or close to from what I remember) of boost. I found it especially annoying when overtaking on a carridge-way when you expected power there was none. I took the vsv's off one by one and ran 12v across them while blowing down one of the ports to see if they opened. The only one that didnt open was the wastegate vsv. I got one for £33 second hand, tried it to see if it opened when it arrived (which it did) fitted it and the problem has never came back Quote Link to comment Share on other sites More sharing options...
