SimonB Posted March 4, 2005 Share Posted March 4, 2005 Need a quick favour from someone with a facelift TT. Can you turn your ignition on (but not the engine) and tell me if the boost and temp gauges move to the bottom line on the scale or stay off the bottom if you see what I mean? Can't remember and I need to put my dial needles back on! Doh! Link to comment Share on other sites More sharing options...
Jake Posted March 4, 2005 Share Posted March 4, 2005 Hold on BRB ................ Link to comment Share on other sites More sharing options...
Ian C Posted March 4, 2005 Share Posted March 4, 2005 I owe you the trip out to the garage in the cold for the RLTC wiring help First image is the gauges with the ignition off, second pic is with the gauges ignition on and mobilised, but without the engine running. Temp gauge stays where it is, although I think it actually moves to the current temperature of the coolant but the car is stone cold so it's rock bottom, and probably this is the only way you'd calibrate it. The boost one moves to the current atmospheric pressure level. The ignition off piccy should give you an idea of where to put the needles anyway...? -Ian Link to comment Share on other sites More sharing options...
Jake Posted March 4, 2005 Share Posted March 4, 2005 The Temp gauge moves from the bottom point when turned off to the first bar of the scale when the ignition is turned on. The Boost gauge moves from the bottom to approx the 0 point (actually slightly below the zero on mine) The 0 point is at the 9 o'clock position of course. Edit : ARRRRRRGGGGGGGGGHHHHHHHHHHHH! Link to comment Share on other sites More sharing options...
Ian C Posted March 4, 2005 Share Posted March 4, 2005 Was your engine completely cold Jake? i know mine stays below the lowest line as shown in the piccies when it's cold and warms up to the lowest line while driving/idling. -Ian EDIT: LOL Link to comment Share on other sites More sharing options...
Jake Posted March 4, 2005 Share Posted March 4, 2005 I got home from work 3 hours ago. Link to comment Share on other sites More sharing options...
SimonB Posted March 4, 2005 Author Share Posted March 4, 2005 Cheers Ian. How bizarre, I've never noticed the boost gauge moving up like that. So what is the atmospheric pressure where you are so I can compensate... I made sure the gauges were at their low values before taking the needles off, figuring that I could put them back on in the same place and all would be well. Unfortunately when you take the needles off the spindles move so when you put them back it's all screwy. So I'm having to hook the ignition up and then put the needles on. Link to comment Share on other sites More sharing options...
SimonB Posted March 4, 2005 Author Share Posted March 4, 2005 Haha, how many people can all post at the same time on the same thread! Link to comment Share on other sites More sharing options...
Ian C Posted March 4, 2005 Share Posted March 4, 2005 So what is the atmospheric pressure where you are so I can compensate... Obviously it's: Link to comment Share on other sites More sharing options...
Jake Posted March 4, 2005 Share Posted March 4, 2005 When did you get a facelift Supra then, Ian? Link to comment Share on other sites More sharing options...
SimonB Posted March 4, 2005 Author Share Posted March 4, 2005 Obviously it's: Aha, approximately 993 millibars, good... Link to comment Share on other sites More sharing options...
Ian C Posted March 4, 2005 Share Posted March 4, 2005 About 3 and a half years ago... -Ian Link to comment Share on other sites More sharing options...
Jake Posted March 4, 2005 Share Posted March 4, 2005 About 3 and a half years ago... LOL! Really? I thought your red car was a UK spec. Dunno why I thought that! Link to comment Share on other sites More sharing options...
Ian C Posted March 4, 2005 Share Posted March 4, 2005 Because it goes so fucking slow up the drag strip? Edited to add - how many times have you heard me gripe about Toyota changing the wire colours on the facelift?! Keep up lad -Ian Link to comment Share on other sites More sharing options...
Markie Posted March 4, 2005 Share Posted March 4, 2005 Damn, should my warning light come on with the ignition in the middle of the speedo??? Hope not, as it does not light up at all Link to comment Share on other sites More sharing options...
Jake Posted March 4, 2005 Share Posted March 4, 2005 Damn, should my warning light come on with the ignition in the middle of the speedo??? Hope not, as it does not light up at all That speedo is a rev counter Markie mate It should be illuminated when the ignition is turned on and the handbrake is on. Link to comment Share on other sites More sharing options...
Nodalmighty Posted March 5, 2005 Share Posted March 5, 2005 Because it goes so fucking slow up the drag strip? Edited to add - how many times have you heard me gripe about Toyota changing the wire colours on the facelift?! Keep up lad -Ian Yeah! But only when Paul W was driving it Nod. Link to comment Share on other sites More sharing options...
Markie Posted March 5, 2005 Share Posted March 5, 2005 That speedo is a rev counter Markie mate It should be illuminated when the ignition is turned on and the handbrake is on. So, are you saying that my car does not rev upto 180,000 RPM's I'd better change the bulb for that bugger then.. What is it a warning for? As my engine lights etc are all fine when starting up... Link to comment Share on other sites More sharing options...
SimonB Posted March 5, 2005 Author Share Posted March 5, 2005 So, are you saying that my car does not rev upto 180,000 RPM's I'd better change the bulb for that bugger then.. What is it a warning for? As my engine lights etc are all fine when starting up... It's the master warning, it comes on when any other warning does. Link to comment Share on other sites More sharing options...
Ian C Posted March 5, 2005 Share Posted March 5, 2005 Yeah! But only when Paul W was driving it Nod. That's a blast from the past mate -Ian Link to comment Share on other sites More sharing options...
