PS3 bluetooth
Tourniquet
I have a Motorolla H300 bluetooth and I've paired it up with the playstation ok and the thing seems to be on but I can't get COD 4 to pick it up. Anyone else had this trouble or know what to do ????
I had my old phone bt on last nite and it worked but was a bit shite so not sure why it's happened
I had the exact same problem!!!! Here's what to do, u've already paired up the device so just go to Accessory settings then scroll down and click on to audio device settings then change your input and output device to your motorola. you can then set your microphone the appropiate level.
From now on all you have to do is start call of duty and turn on your motorola and it will come straight on.
Hope this helps
Add me if u like my username is beefyblx
