high rpm rattle
supratoy
I have a non stock flywheel and clutch so it rattles on idle but
suddenly after fitting the stock fan and shroud(radiator is to phat:rolleyes: still sorting it out properly)
Anyways there is a rattle thats coming through the car only at over 5000rpm in 1st to 3rd not tried the higher gears because of the fan and shroud, could this be the clutch release bearing?
cheers
It's exhaust valve located just under turbo's heatshield. Have the same rattle when revving engine over 5k (not recommended), and when valve is coming back you will hear this sound. Nothing to worry about, apparently it's normal :)
Its when am moving though not just free revving, its as soon as your around 5000rpm on boost and you feel and hear the rattle.
