Mains electrical help
firepool
Im changing a pull cord switch for my extractor in the bathroom and the new one seems to have different terminals.
The old one has 5 terminals; L com, L 1-way, N, N 2-way and E.
The new one has 4 terminals; L1, L2, com and E.
Does anyone know the correct way to wire this?
The old one
The new one
Looking at the pictures, I'd say the first one is an isolator switch which is double pole. Ie it breaks both the Line (live) and Neutral. However the new one appears to be a standard two way switch.
When you removed the old wiring was there a black or blue wire in both 'N' and 'N-2way' and a red or brown wire in both 'L' and 'L-1 way'.
Almost half price at Screwfix compared to B & Q. :)
Use Screwfix or a similar shop whenever you can as B & Q can be extortionate especially for screws.
http://www.screwfix.com/prods/88758/Electrical/Switches-Sockets/White-Moulded/Volex-Range/Volex-50A-Ceiling-Sw-Neon
There's a free coffee machine at the Screwfix near me . :)
ps. Only mess with electricity if you're 100% confident that you know what you're doing. :shock:
Ok. I've bought another switch, think its the right one this time with 5 terminals; 1 L and 1 N on SUPPLY side and 1 L and 1 N on LOAD side (plus an earth in the casing).
Only 1 of the wires is 'live' coming down from the ceiling, should this be connected to the L SUPPLY or L LOAD?
I'd have said the mains ring (i.e. the cable coming from the ceiling) is the "supply" and the fan is the "load"!
BTW you're breaking the new laws by working on electrics in your bathroom, I think. I know you can do basic wiring jobs like changing switches elsewhere in the house, and perhaps a fair bit extra, but I don't think you can in the kitchen & bathroom because of the moisture factor and extra issues that could bring.
think you answered your own question if its coming down the ceiling and its not on load ie. supplying the feed to the bulb/fan then it would be the supply.
Just dont get changing any intermediate switches please
Yes. :)
I didn't know that, I thought it was all outlawed.
I had a quick search on Google, you are correct. :)
  Quote
On January 1st 2005 legislation came into effect which brought electrical work in dwellings under the Building Regulations, and made it a controlled service. This amendment to the Building Regulations, known as "Part P", imposes safety requirements, and also classifies electrical installation work into two basic categories, notifiable and non-notifiable.
Essentially the distinction is between major work, or work in what are deemed high-risk areas such as kitchens, bathrooms and gardens, and minor work such as replacing switches or adding sockets to existing circuits. (NB to those with a knowledge of the IEE Wiring Regulations, the term "minor work" is used here in its generic sense rather than the meaning defined in the Wiring Regs.)
The red from the power supply(live feed) goes into supply L
The black from power supply(live feed) goes into supply N
The red that goes to the fan goes into load L
The black that goes to the fan goes into load N
Hope this helps and turn the mains off before you do it,or at least the lighting fuses
Thanks very much gordy, I just missed your post but was on way to do it exactly how you just said! Its wired to the 1st floor lighting circuit so I isolated that before I done anything. Its working fine now with all connections nice and tight.
Thanks for all your help people ;)
