Ryan.G remap
Axle
Absolutely. :thumbs:
Just to be clear; I wasn't slagging off your car, or SRR's dyno - just questioning a HP figure that, to my (possibly flawed) understanding is higher than could be achieved with stock injectors/FPR.
No big deal.
:grouphug:
Its ok even if you were slaggin my car off i wouldnt hold it against you. Some people hate Automatics, thats fair play. I dont get that personal over my cars. As much as i love them! :gayfight:
I may fit larger injectors for safety tbh.
I totally see where you're coming from jake.
The results would initially suggest that the car is running almost at 100% efficiency (it's far too early to do the laths at the moment!)
The only way I see this as being possible, and what I think is the most likely cause is that the stock pressure regulator according to the workshop manual has quite a large range that it can output and still be within tolerance. So effectively he'll be running a higher base pressure.
I can't see how else it can do it otherwise.
Edited by TLicense (see edit history)
