Carl Posted August 27, 2008 Share Posted August 27, 2008 I have long had an issue with my auto box but have put up with it as it only occurs on full throttle, usually higher speed situations but I want to get this sorted. Basically, if I floor the car throught the gears sometimes between 2nd to 3rd and nearly always between 3rd to 4th the revs hit the limiter before changing up. Sometimes I have to lety off the gas a little to allow the gear to change up then re-apply the gas again. Not what you what to do in an auto. I have been told that the most likely cause is probably the kick down throttle cables may need adjusting as they have become tight or even sticking due to lack of lubrication. This will often lead to kickdown mode holding in that particular gear for too long as I experience, hence letting off allowing it to change up. However, some TT's use the cables, some use an electronic controller of some sort. Apparently there are two of these kick down cables but I must admit I cant see them so Im thinking that probably mine has the electronic type. Can somebody clarify this for me and maybe shed some light on best way to adjust? hopeing someone else has had similar fault and cured in the same way. I'm told this is more common on the VVTI's. Chees in advance. Link to comment Share on other sites More sharing options...
Paul372 Posted August 27, 2008 Share Posted August 27, 2008 sounds like you might have the same problem has me heres my thread take alook http://www.mkivsupra.net/vbb/showthread.php?t=160100 Link to comment Share on other sites More sharing options...
Carl Posted August 27, 2008 Author Share Posted August 27, 2008 sounds like you might have the same problem has me heres my thread take alook http://www.mkivsupra.net/vbb/showthread.php?t=160100 Mine has never ceased to change up tho, it's just that I have had to let of the throttle a bit to help it through. An annoying issue none the less. Under normal conditions this problem never occurs. Its been like it for the last 2.5 years but I have never bothered to look at it as its not often I hit the speed to cause the problem. It's certainly never got any worse for me which is why I feel mine is some sort of kickdown adjustment rather than a mechanical box failure. Carl Link to comment Share on other sites More sharing options...
Dazzi Posted August 27, 2008 Share Posted August 27, 2008 Isn't there a little catch of some sort under the accelerator? When you put your foot to the floor to accelerate and press it slightly more you should feel the pedal go down about 1cm or so, im sure this is an override to tell the box to shift...? Sorry its been a while since I was in an auto Link to comment Share on other sites More sharing options...
ManwithSupra Posted August 27, 2008 Share Posted August 27, 2008 I had this once posted on here advised to pull the ECU fuse and all was well.... try that. Link to comment Share on other sites More sharing options...
baldy Posted August 27, 2008 Share Posted August 27, 2008 mine was doing this turned out to be the tps on the trac butterfly,needed setting up properly http://www.max-boost.co.uk/max-boost/resources/SUPRA_MKIV/ThrottleTPSDiagram_diagnostics.pdf i used this to sort mine Link to comment Share on other sites More sharing options...
mrdsukautos Posted August 29, 2008 Share Posted August 29, 2008 This could also be a speedo chip issue i use same chips as Jurgen the NCS ones and if you fit a pro chip this can cause the same problem changing it out to a non pro ncs chip fixed problem Link to comment Share on other sites More sharing options...
