JamieP Posted August 26, 2008 Share Posted August 26, 2008 These look good, rekon my car will go up on these? http://cgi.ebay.co.uk/Sports-car-long-low-angle-lifting-Ramps-2000Kg-a-pair_W0QQitemZ110277775890QQcmdZViewItem?hash=item110277775890&_trkparms=72%3A984%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14 Link to comment Share on other sites More sharing options...
merckx Posted August 26, 2008 Share Posted August 26, 2008 I've just been using a pair that my brother bought from the same seller. Link to comment Share on other sites More sharing options...
Hermit Posted August 26, 2008 Share Posted August 26, 2008 Dunno... mine does Get your tape measure out - they go up 10" in 58" if that's any help? Link to comment Share on other sites More sharing options...
heckler Posted August 27, 2008 Share Posted August 27, 2008 I just use paving slabs Link to comment Share on other sites More sharing options...
ManwithSupra Posted August 27, 2008 Share Posted August 27, 2008 I think i am going to get a set Link to comment Share on other sites More sharing options...
ShamelessTT Posted August 27, 2008 Share Posted August 27, 2008 2bh i made some out of wood (well my old man did) absolutely solid (can get pic if u wanna see how they were done). I never trust the welded ones, i bought some from a motor company a while ago, not bad but the welds didnt look up 2 much and werent totally flat sitting on the floor without weight. Save urself probably a 130 sheets and get some tough wood and DIY it....... Link to comment Share on other sites More sharing options...
Hermit Posted August 27, 2008 Share Posted August 27, 2008 2bh i made some out of wood (well my old man did) absolutely solid (can get pic if u wanna see how they were done). I never trust the welded ones, i bought some from a motor company a while ago, not bad but the welds didnt look up 2 much and werent totally flat sitting on the floor without weight. Save urself probably a 130 sheets and get some tough wood and DIY it....... Hmm... how much do they weigh? Less than paving slabs I suppose Dunno how much you paid for the welded ones you got, but maybe it's a case of 'you get what you pay for'? These might cost 130, but they sit flat on the floor and, while I'm no expert, the welds look pretty good. Link to comment Share on other sites More sharing options...
gordy07 Posted August 27, 2008 Share Posted August 27, 2008 I dont think i would trust wood or slabs tbh:blink: I might invest in a set of metal ones though they look good:) Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted August 27, 2008 Share Posted August 27, 2008 i bought a set of ali ones they look a lot better (they are also lighter and also smaller in height) Link to comment Share on other sites More sharing options...
Scooter Posted August 27, 2008 Share Posted August 27, 2008 I dont think i would trust wood tbh:blink: The wooden ones will i think be of solid construction ie several planks on top of eachother, firmly fixed together and then the slop cut into them, there is nothing to not trust as (unlike even the metal ones) there is no air between the car and the ground just solid wood. Link to comment Share on other sites More sharing options...
tDR Posted August 27, 2008 Share Posted August 27, 2008 How much use are ramps like these really though? OK you can get the car in the air, but you can't do an oil change for example.... Link to comment Share on other sites More sharing options...
gordy07 Posted August 27, 2008 Share Posted August 27, 2008 The wooden ones will i think be of solid construction ie several planks on top of eachother, firmly fixed together and then the slop cut into them, there is nothing to not trust as (unlike even the metal ones) there is no air between the car and the ground just solid wood. Now you explain it like that it makes sense:) I pictured a wooden framed ramp not a solid one:slapped:me:d Link to comment Share on other sites More sharing options...
jacko Posted August 27, 2008 Share Posted August 27, 2008 a few bits of 2x2 lol Link to comment Share on other sites More sharing options...
Wez Posted August 27, 2008 Share Posted August 27, 2008 I have always fancied a set of these http://www.restorationramps.co.uk/phdi/p1.nsf/supppages/ramps?opendocument&part=2 Link to comment Share on other sites More sharing options...
Scooter Posted August 27, 2008 Share Posted August 27, 2008 How much use are ramps like these really though? OK you can get the car in the air, but you can't do an oil change for example.... i know what you mean................if i had them i think once its up and the wheels are on the flat part i'd have to have use a trolley jack and wood etc and lift it a bit more on the central crossmember and then flip the ramps 180 degrees or just replace with axle stands before relowering. The attraction i spose is an easy (practically and on the car and the your lifting gear) lift in the first place, rather than faffing around with jacks on/near the sills and a bit one side and then the other before you can really get under it properly? Link to comment Share on other sites More sharing options...
Scooter Posted August 27, 2008 Share Posted August 27, 2008 I pictured a wooden framed ramp not a solid one:slapped:me:d Indeed that would be a worry ...................reminds me of those (ok a bit nerdy) science contests to construct a bridge that can handle the max weight but only be made out of a limited number of matchsticks Link to comment Share on other sites More sharing options...
AshBhp Posted August 27, 2008 Share Posted August 27, 2008 (edited) These are nice and strong. They ship to UK at fair price. http://www.raceramps.com/store/shopexd.asp?id=83 Edited August 27, 2008 by AshBhp (see edit history) Link to comment Share on other sites More sharing options...
Hermit Posted August 27, 2008 Share Posted August 27, 2008 How much use are ramps like these really though? Enabled me to replace my blown turbos myself, so they've paid for themselves already I just feel happier going under the car when it's wheels are on something rather than using axle stands. Link to comment Share on other sites More sharing options...
gordy07 Posted August 27, 2008 Share Posted August 27, 2008 Indeed that would be a worry ...................reminds me of those (ok a bit nerdy) science contests to construct a bridge that can handle the max weight but only be made out of a limited number of matchsticks lol me too i was sh!te at them:d Link to comment Share on other sites More sharing options...
extendor Posted August 27, 2008 Share Posted August 27, 2008 I bought a 2 sets of standard rams from the recycling centre at the tip for £10. Cut one pair down by slicing approx 3" as a wedge out of the middle. Then reweld them back together. I also cut the tyre stop off the ends and flared the ends out so the shallow ramp would fit over and onto the steeper ramp. That way you get a two stage ramp which works brilliantly. Cost me £10 about three hours a tin of old hammerite to make them pretty. The baeuty is that when the car is up on the ramps you remove the shallow ramp and have unobstructed access around the sills etc. I will try to put up a piccy tomorrow to show you. Link to comment Share on other sites More sharing options...
Rajinder Posted August 27, 2008 Share Posted August 27, 2008 We use these and they are good enough for an oil change or other minor work under the car. Link to comment Share on other sites More sharing options...
Wez Posted May 18, 2009 Share Posted May 18, 2009 Waking up an old thread as I have just come across these, they seem pretty good http://hamercarlift.com/ Link to comment Share on other sites More sharing options...
extendor Posted May 26, 2009 Share Posted May 26, 2009 I made these and they work great. Link to comment Share on other sites More sharing options...
peter richards Posted May 26, 2009 Share Posted May 26, 2009 been thinking about this for a while now as it would make it easier to machine the lower panels, and looking at some of those pics wouldnt be to difficult to make either, only a few bits of angle iron couple of days welding Link to comment Share on other sites More sharing options...
mplavery Posted May 26, 2009 Share Posted May 26, 2009 dame work computers, i cant view it, do you lot think a DO-LUCK bumper go over it ok ? Link to comment Share on other sites More sharing options...
