Engine Damper
Chingy
Col do you have a photo to show how the turbo sits?
How wide is the V-band/T4 adapter? Is it an HKS adapter? It may be possible to fit a narrower one so there is more clearance.
I've just been outside to test mine, I have the factory fitted OEM engine mounts and get around 5mm movement at the turbo at high rpms, the TRD mounts should minimise this a bit.
Other option would be to cut the V-band flange off the manifold and get a T4 flange welded on, although this could create a weak point on the manifold.
Some great advice thank u mate, will have a measure up on the adapter didn't even think about that, couple of pics I had on't know if they help, will have to have a better look
Another thought, is not possible to rotate the adapter where it connects to the V-band flange on the manifold to give a bit of extra clearance?
Looking at the overhead shot if you rotated the adapter anti-clockwise a little on the manifold, it should give you more clearance.
That would definately make sense:thumbs:, will have a look at that tomoro, only needs a little more clearance
If you do need a damper I can get these ones, they are better quality compared to the US one, but are still quite solid. It would need brackets fabricating though as there isn't a kit for the Supra.
http://www.hpi.co.jp/products/engine/md/picsmaxeng1.jpg
that looks alot better quality, got ur prices on the trd mounts can u let me know what sort of money and delivery time is on these
http://img241.imageshack.us/img241/974/959111109cg7.jpg
Has anyone used one of these or know if there are any others availible for the supra. Also would like to keep my strut brace if at all possible Any help would be great ;)
I asked the very same question back in February when Nic was selling one, but you got a better set of replies!
http://www.mkivsupra.net/vbb/showthread.php?t=141081
Edited by Tee from China (see edit history)
