supradibbs Posted August 28, 2008 Share Posted August 28, 2008 colin to be honest i would go with the trd mounts SRD would be able too do that for you no probs means lifting the engine off course Quote Link to comment Share on other sites More sharing options...
Chingy Posted August 28, 2008 Author Share Posted August 28, 2008 The reason its so close is because he is running a T51 v-band manifold with a T4 adapter so the T04-Z fits;) should of kept the T51 Quote Link to comment Share on other sites More sharing options...
Chingy Posted August 28, 2008 Author Share Posted August 28, 2008 Col do you have a photo to show how the turbo sits? How wide is the V-band/T4 adapter? Is it an HKS adapter? It may be possible to fit a narrower one so there is more clearance. I've just been outside to test mine, I have the factory fitted OEM engine mounts and get around 5mm movement at the turbo at high rpms, the TRD mounts should minimise this a bit. Other option would be to cut the V-band flange off the manifold and get a T4 flange welded on, although this could create a weak point on the manifold. Some great advice thank u mate, will have a measure up on the adapter didn't even think about that, couple of pics I had on't know if they help, will have to have a better look Quote Link to comment Share on other sites More sharing options...
Nic Posted August 28, 2008 Share Posted August 28, 2008 Another thought, is not possible to rotate the adapter where it connects to the V-band flange on the manifold to give a bit of extra clearance? Looking at the overhead shot if you rotated the adapter anti-clockwise a little on the manifold, it should give you more clearance. Quote Link to comment Share on other sites More sharing options...
Chingy Posted August 28, 2008 Author Share Posted August 28, 2008 Another thought, is not possible to rotate the adapter where it connects to the V-band flange on the manifold to give a bit of extra clearance? That would definately make sense:thumbs:, will have a look at that tomoro, only needs a little more clearance Quote Link to comment Share on other sites More sharing options...
Nic Posted August 28, 2008 Share Posted August 28, 2008 If you do need a damper I can get these ones, they are better quality compared to the US one, but are still quite solid. It would need brackets fabricating though as there isn't a kit for the Supra. http://www.hpi.co.jp/products/engine/md/picsmaxeng1.jpg Quote Link to comment Share on other sites More sharing options...
Chingy Posted August 28, 2008 Author Share Posted August 28, 2008 If you do need a damper I can get these ones, they are better quality compared to the US one, but are still quite solid. It would need brackets fabricating though as there isn't a kit for the Supra. http://www.hpi.co.jp/products/engine/md/picsmaxeng1.jpg that looks alot better quality, got ur prices on the trd mounts can u let me know what sort of money and delivery time is on these Quote Link to comment Share on other sites More sharing options...
bolarbag Posted August 28, 2008 Share Posted August 28, 2008 that looks alot better quality, got ur prices on the trd mounts can u let me know what sort of money and delivery time is on these snap, just waiting to hear back about the other parts Nic, cheers;) Quote Link to comment Share on other sites More sharing options...
Nic Posted August 28, 2008 Share Posted August 28, 2008 snap, just waiting to hear back about the other parts Nic, cheers;) Just checking prices, it may take a few days as my contact is out of the office today. Quote Link to comment Share on other sites More sharing options...
bolarbag Posted August 29, 2008 Share Posted August 29, 2008 Cheers! Quote Link to comment Share on other sites More sharing options...
Tee from China Posted August 30, 2008 Share Posted August 30, 2008 (edited) http://img241.imageshack.us/img241/974/959111109cg7.jpg Has anyone used one of these or know if there are any others availible for the supra. Also would like to keep my strut brace if at all possible Any help would be great I asked the very same question back in February when Nic was selling one, but you got a better set of replies! http://www.mkivsupra.net/vbb/showthread.php?t=141081 Edited August 30, 2008 by Tee from China (see edit history) Quote Link to comment Share on other sites More sharing options...
