banaman69 Posted August 23, 2002 Share Posted August 23, 2002 i have a slight idling problem,sometimes it idles at 1k and then sometimes 650.i have checked all hoses ok,could it be the icv if it is is it possible to strip down to inspect? jap spec tt. Quote Link to comment Share on other sites More sharing options...
Alex Posted August 23, 2002 Share Posted August 23, 2002 ICV? Is that the idle control valve?? errm well any way mine was sticking so i sprayed it with WD-40 and its not stuck since. Also try lubing/adjusting the throttle cable if necessary. Is 3-in-1 oil ok for that??? Not sure. Quote Link to comment Share on other sites More sharing options...
eyefi Posted August 23, 2002 Share Posted August 23, 2002 where is the icv? Quote Link to comment Share on other sites More sharing options...
banaman69 Posted August 23, 2002 Author Share Posted August 23, 2002 actually i should of said the isc(idle speed control) valve. Quote Link to comment Share on other sites More sharing options...
Alex Posted August 23, 2002 Share Posted August 23, 2002 Its the unit on the opposite side of the throttle body to the throttle cable itself. When the engine is switched off push the throttle open and you'll see the actuator which moves slightly to adjust the throttle. I sprayed mine with WD-40 and it seems to be working much more evenly now. Quote Link to comment Share on other sites More sharing options...
