Jspec Autobox Speed sensor question,
ManwithSupra
How many Speed sensors does the Jspec Autobox have?
Looking at the ECU pinouts (see attached) that are provided (very kindly by Ian c) it looks as if it only has 1 ?? is this the case?
If so is the sensor on the jspec the same as Speed sensor 2 on the UK/US spec??
Jap%20spec%20pinouts[1].doc
UK spec pinouts.doc
Edited by ManwithSupra (see edit history)
The uk spec speed sensor will fit the jspec BUT the plastic gear is of a different ratio so you will have to just pull the gear out and fit your jspec one in there.
Cheers dude for that info - may come in handy cheers :)
However i am not trying to put the UK spec speed sensor in the Jspec gearbox as yet.
Looking at the UK/US spec ECM pinouts there is Speed sensor 1 (which is gear driven) and speed sensor 2 (which is pulsed by a magnet and rotor)
On the Jspec ECM pinouts there are pins just for speed sensor 1 and no mention of speed sensor 2 but i cant find out whether this is gear driven or pulse driven...
Does anyone know if Speed sensor 1 on the Jspec is the same as Speed sensor 2 on the UK/US spec??
I have attached a couple of pics of the repair manual to show you what sensors i am on about (however the manual does not detail what is and what is not included with the different country models)...not sure if that helps.
Yeah i have seen that site before had a good scour through its got some very useful info on there.
But i am not fitting anything at all, just an answer to my question about the speed sensor difference....i take it by now no one knows so i think i will leave it there and struggle through :)
Hey ho :D
