my new telly
liam1
brilliant picture, does it not come calibrated for this?
It can't. ISF calibration is done per source - basically, the input will vary so the calibration gives the best picture for that. When I had mine calibrated, each source (sky direct to TV, ps3 games, ps3 bluray, sky through surround amp) were calibrated separately. The pic was amazing.
By the way - you don't want the 8th Gen Pioneer (which I've got) - you want the 9th Gen. Saw it at CEDIA - amazing.........
Very nice.
A couple of years ago I bought a 42" HD plasma for my lounge at the flat, as it was a huge room, it fitted nicely in there, but now I've moved to a house with a smaller lounge it looks enormous mounted there on the chimney breast!
It now feels like you're right in there with everything! :D
how do you get them calibrated???
You go somewhere like AV Forums where there are qualified ISF calibration engineers. Nothing is free of course - I think I paid around £300. Worth every penny though.
Note that not all sets can be calibrated. PDP428XD can - PDP4280 cannot.
Spot on,
as an example, off AV Forums this is a calibration sheet for the PS3 etc input on the Pioneer which you can do yourself....
These settings should be applied to the letter, you can adjust sharpness and saturation to suit but don't alter colour temp or colour mangement away from the settings below.
For SKY HD, PS3, Blue Ray or HD/DVD (BLUE RAY, PS3 OR HD/DVD YOU NEED TO ADJUST PURE CINEMA)
(SKY HD SET PURE CINEMA TO OFF)
AV SELECTION ***MOVIE***
CONTRAST 30
BRIGHTNESS 0
COLOUR -2
TINT +2 Towards Green
SHARPNESS -15
PRO ADJUST > PURE CINEMA
FILM MODE OFF (BLUE RAY/HD DVD Smooth or Advanced)
TEXT OPTIMISATION OFF
INTELIGENT MODE OFF
PICTURE DETAIL
DRE OFF (Low if you prefer)
BLACK LEVEL OFF
ACL OFF
ENHANCER MODE 2 (1 if you prefer)
GAMMA 2
COLOUR DETAIL MANUAL (HOLD ENTER FOR 3 SECS)
COLOUR TEMP
R High -2
G High 0
B High +2
R Low -1
G Low 0
B Low -1
CTI OFF
COLOUR MANAGEMENT
R 0
Y 0
G 0
c 0
B 0
M -7
COLOUR SPACE 1
If you're using a PS3 via HDMI with this TV, there is a bug that will destroy shadow and highlight details if you have "RGB Full Range" enabled in the PS3's display settings. I won't go into the technical details as to why, but to set up your PS3 properly with this TV, you should go to:
1: Settings > Display Settings > RGB Full Range (HDMI) set it to "Full"
2: Settings > BD/DVD Settings > BD/DVD Video Output Format (HDMI) and change it to "RGB"
3: TV Menu > Option > HDMI Input > Video and change it from "Auto" to "Colour-4"
After a second or two, you should see the image change to a lower contrast, and far more accurate image.
NOISE REDUCTION
Field NR OFF
All others OFF
OTHERS
IP MODE 1 "
as you see a myriad of settings, for Freeview, X-Box, HTPC different settings again, a bit of faffing about i know but can you complain about the end result.....--->
http://img180.imageshack.us/img180/3872/2713222600951077f76eolt1.jpg
The settings above can be done to the 4280 as well - ISF calibration is more than that (it was quite fascinating to watch actually).
I used the AV Forums settings before getting it ISF calibrated - and to be honest, I was dubious I would see much difference. But it made a very noticeable difference, especially to dark scenes.
