Paul372 Posted August 23, 2008 Share Posted August 23, 2008 i was in my supe not far from home and i gave it some beans when pulling away and the auto box didnt change up it just rev right out like a clutch sliping and now it wont change up, does anyone know what up with it, has my auto had it? Quote Link to comment Share on other sites More sharing options...
supra matt Posted August 23, 2008 Share Posted August 23, 2008 Have you checked your not in manual mode mate? if your not check the oil Quote Link to comment Share on other sites More sharing options...
Paul372 Posted August 23, 2008 Author Share Posted August 23, 2008 no its not in manual mode, oil fine check it all the time but maybe time for oil change Quote Link to comment Share on other sites More sharing options...
supra matt Posted August 23, 2008 Share Posted August 23, 2008 when you say wont change up is it stuck in frist? if so put it in manual mode and use the L, 2 and d and see if it changes Quote Link to comment Share on other sites More sharing options...
Paul372 Posted August 23, 2008 Author Share Posted August 23, 2008 it drives in L, 2 and D and changes up when using the gear stick manualy but when its in D it does nt just revs out Quote Link to comment Share on other sites More sharing options...
supra matt Posted August 23, 2008 Share Posted August 23, 2008 That's strange then mate may be a problem with the ecu! Quote Link to comment Share on other sites More sharing options...
Paul372 Posted August 23, 2008 Author Share Posted August 23, 2008 i will have to take a look tomorrow in the daylight and drive it to see if it does it cheers anyway mate, i will post back up tomorrow once i ve had a look at it Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted August 24, 2008 Share Posted August 24, 2008 Your torque convertor has had its day I think. Same problem with mine about a year ago It was fine when driving at low revs, but once I gave it some the revs shot up and it kept hitting the limiter managed to pick a lower milage box and convertor up for around £200 Quote Link to comment Share on other sites More sharing options...
Paul372 Posted August 25, 2008 Author Share Posted August 25, 2008 Your torque convertor has had its day I think. Same problem with mine about a year ago It was fine when driving at low revs, but once I gave it some the revs shot up and it kept hitting the limiter managed to pick a lower milage box and convertor up for around £200 drove it today fine at low revs driving it around normal but like you sad when i give it some the revs shot up and hits the rev limiter so you think my torque convertor has had it:( Quote Link to comment Share on other sites More sharing options...
Paul372 Posted August 26, 2008 Author Share Posted August 26, 2008 how big of a job is it to replace the torque convertor is it easy to do Quote Link to comment Share on other sites More sharing options...
tDR Posted August 26, 2008 Share Posted August 26, 2008 how big of a job is it to replace the torque convertor is it easy to do Bit like changing a clutch work wise - best way to go about it is unbolt the TC from the flex plate (the bit instead of a flywheel on an auto) then take the autobox off with the TC still on the input shaft, as you would a manual - exhaust off, propshaft off etc. To me though it's probably the autobox that's had it - worn clutch packs or similar. The strange thing with autoboxes is they apparently use a different set of components inside when shifting manually than when just using D, which could tie up with what you're saying about it being OK when shifting manually. Cheers, Brian. Quote Link to comment Share on other sites More sharing options...
Paul372 Posted August 26, 2008 Author Share Posted August 26, 2008 so it might not be the torque convertor could be the auto box its self, do you think it will still be ok to do a major service on it before i sort out this problem or should i wait untill i get this fixed Quote Link to comment Share on other sites More sharing options...
tDR Posted August 26, 2008 Share Posted August 26, 2008 Fix the problem first - I'm guessing a major service would include full autobox fluid change so that would really be a waste with a knackered autobox. Source a 2nd hand autobox / TC combo - shouldn't be more than £300 on here for something decent, then give it to the garage doing the major service to change over whilst doing the major service so the nice new fluid etc. goes in the replacement box / TC. Cheers, Brian. Quote Link to comment Share on other sites More sharing options...
Paul372 Posted August 26, 2008 Author Share Posted August 26, 2008 ok thanks mate i will do that, i think thats the best bet to replace the auto box with a new 2nd hand one with tc with it that way its done in one hit rather than just replacing the tc and then finding out the auto box is knackered Quote Link to comment Share on other sites More sharing options...
Paul372 Posted August 26, 2008 Author Share Posted August 26, 2008 would it be worth getting the auto box and tc recon Quote Link to comment Share on other sites More sharing options...
tDR Posted August 26, 2008 Share Posted August 26, 2008 would it be worth getting the auto box and tc recon The cost will be prohibitive compared to 2nd hand. The other choice is to go aftermarket 'uprated' such as the Boostlogic autobox and an aftermarket higher stall TC like a Precision Industries. You're looking at in excess of £2k for such a setup though so only worth considering if you have bigger power goals for your car in mind... Cheers, Brian. Quote Link to comment Share on other sites More sharing options...
Paul372 Posted August 26, 2008 Author Share Posted August 26, 2008 thanks for the advice Brian Quote Link to comment Share on other sites More sharing options...
Supranature Posted August 26, 2008 Share Posted August 26, 2008 Theres a box going on e-bay with a start bid of £150, in Hinckley. Quote Link to comment Share on other sites More sharing options...
Paul372 Posted August 26, 2008 Author Share Posted August 26, 2008 Theres a box going on e-bay with a start bid of £150, in Hinckley. thanks mate i will have alook Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted August 26, 2008 Share Posted August 26, 2008 I used this guide (Thanks Pete) when changing my autobox. It was very helpful and easy to follow the step by step procedure. Take a look and see what you think http://www.mkivsupra.net/vbb/showthread.php?t=72771 (download the .pdf file) Note: You'll need to do this over a pit or a 2 poster ramp, definately wouldn't like to try doing this with axle stands! lol Also bear in mind the box is heavy (took 4 of us to lift it and one to locate the bolts) so make sure you have a few friends willing to get their hands dirty Quote Link to comment Share on other sites More sharing options...
tDR Posted August 27, 2008 Share Posted August 27, 2008 It's not so bad on axle stands. Yeah a pit or ramp would be a lot nicer but it is manageable on stands. I've done my box swaps with my Dad and we find the weight ok between us - usually me man handling stuff whilst he bolts it up. Using trolley jacks is a good way to make it all more manageable whilst crawling about under the car - we tend to use a flat but thick bit of wood on one then mount the autobox lengthways on it and guide it into place from the rear of the car, jacking the box up to the right height as we go. It also helps to jack the front of the engine up via that end of the sump with another block of wood inbetween, this lets you get a better angle to get the autobox on and off in the first place. Remember to disconnect your IC pipes if doing that though. Cheers, Brian. Quote Link to comment Share on other sites More sharing options...
Paul372 Posted August 27, 2008 Author Share Posted August 27, 2008 thanks guys for all the help really appreciate it, that thread will come in handy when i do source a good auto box with torque converter i think i will have ago doing it myself what seals will i need to replace under there Quote Link to comment Share on other sites More sharing options...
