Wez Posted August 20, 2008 Share Posted August 20, 2008 Hey All, Does anyone know the diameter of the stock power steering cooler pipework? Thanks Quote Link to comment Share on other sites More sharing options...
dandan Posted August 20, 2008 Share Posted August 20, 2008 From memory the hardpipes are 10mm outside diameter, how exact do you need it? Quote Link to comment Share on other sites More sharing options...
Wez Posted August 20, 2008 Author Share Posted August 20, 2008 Just wondered thats all, thanks. Quote Link to comment Share on other sites More sharing options...
Wez Posted September 4, 2008 Author Share Posted September 4, 2008 I think this cooler should do the trick, any thoughts? PS Cooler Quote Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted September 4, 2008 Share Posted September 4, 2008 I used 10mm (3/8" near enough) ID rubber hose on mine. The cooler looks plenty big enough compared to the stock cooling loop. Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 5, 2008 Share Posted September 5, 2008 -6 I believe Wes, if your doing it in braided that is. Quote Link to comment Share on other sites More sharing options...
bolarbag Posted September 5, 2008 Share Posted September 5, 2008 Is there any disadvantages to making them bigger, I'm sure mines are -8, I'll confirm tonight, my reservoir to pump is -10 Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 5, 2008 Share Posted September 5, 2008 Bugger, your right, its -8, but pump to reservoir pipe is -12. Quote Link to comment Share on other sites More sharing options...
Wez Posted September 5, 2008 Author Share Posted September 5, 2008 Thanks guys, I check yesterday and it is indeed -8an which is .450in roughly 10mm Quote Link to comment Share on other sites More sharing options...
bolarbag Posted September 5, 2008 Share Posted September 5, 2008 Bugger, your right, its -8, but pump to reservoir pipe is -12 Are you sure its -12AN, the oem part that connects to the pump has been retained, cut and welded with a -10AN on mine, there is no way you would manage to fit a -12AN on flush, the diameter of a -12AN fitting is bigger than the oem part too Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 5, 2008 Share Posted September 5, 2008 Yep, just checked on my own car. Quote Link to comment Share on other sites More sharing options...
