STD ECU Capabilities.
Tricky-Ricky
IMO on an ecu reset nothing changes and its all in the mind. ;)
Ryan[/quoteI
i have always believed in the above statement ;):innocent:
Thanks for the info Ryan, will have a read, at a glance it looks similar to the Consult software that was available for Nissan's, so you could read the std maps, something like that for the Supra wold be good:)
Edited by Tricky-Ricky (see edit history)
LOL! Noooooo! thats the whole point of the thread:p:d
It makes for an interesting discussion though;)
Haha, you know what I meant :p
Besides, it's turned out to be us lot learning from Matt and Ryan's experiences, which is just dandy :D Thanks guys :thumbs:
Shall we complicate things a little more and bring the Mines altered OEM ECU into the discussion.
e.g. In addition to fuel cut and rev limit increase, what about the ignition timing changes from the Mines ecu? Would the OEM ecu still pull timing back and then re-introduce it like normal when the Mines daughterboard is trying to advance it more than normal?
My stock ECU IS a modified one. Has caused problems with the E-manage in the past.
I would imagine yes it would, has the Mines altered ECU actually got an add on daughter board? or does it just have rewritten ROM chip, the latter i would have thought, as its more cost effective.
I thought (could be wrong though as I can't remember where I read it) that the stock ECU stores the adjustments it last made at a particular map point while in closed loop. Kind of a long-term trim value. So if you reset it it would take a bit longer to settle down to 14.7AFR while crusing/idling/low load.
EDIT:Ah, in fact Wilbo has just said the same!
Guest wilbo666
With the Toyota engine ECUs (i.e. the JZA80), the microcontrollers code including the 'maps' or tuning data is stored in mask ROM (http://en.wikipedia.org/wiki/Mask_ROM) in the mircontroller.
It isn't possible to change the mask ROM in the microcontroller... it is however possible to put the microcontroller into a mode so that it doesn't use its internal code (in the mask ROM), but accesses code in an external memory.
So in general to make the Toyota ECU's 'programmable' you use a daughter board, with external memory that you can change / modify :) If the external memory is loaded with same data as the mask ROM then it would work the same as a stock ECU (it isn't quite that easy tho as some of the pins on the micro that are used for other functions are needed to read the external memory, these are then remapped to memory locations...) :)
This is just my understanding, and might be wrong and incorrect in some regards. I think the basics of it are right tho :)
Cheers
Wilbo
Inside the Tom's modified JZZ30 ECU I have here there's a daughter board with CPU and ROM chips. This replaces the original CPU which presumably had ROM built into it. So it's both :) but effectively a rewritten ROM chip.
Wilbo, that seems to be general ECU behaviour already mentioned, rather than Supra specific.
They said that the Nissan ECU ROMs couldn't be rewritten but all it takes is for the original ROM chip to be replaced with a rewritable one, its extracting the data contained that was a stumbling block, i suspect that nobody has spent that much time on the the Supra ECU other than Mines ( and there not saying;)), because most of the big power conversions done to the Supra call for a stand alone ECU.
Ahh i stand corrected, sounds like its the same as the Nissan S15 ECUs they need an add on daughter board to interface with the original ECU and rewritten ROMs added.
The mines ecu is quite a complicated bit of kit. They remove 2 big chips from the stock board and attach the mines daughter boards to the motherboard in place of those big chips. This is the inside of mine, its from an auto so i assume that one of those daughterboards is to run the gearbox:
The ECU has short term and long term fuel trims. :)
Sure, but it's true of the Supra as well. It certainly explains why some cars take a while for their idle to settle after a reset. Mine doesn't, which I'll take as a good thing :)
I guess the long term fuel trim is basically calibrating the ECU to the fuel delivery system of the car, but does that trim then get used for open loop operation as well as closed loop? It would at first glance seem logical if it did, but from what I've heard, open loop operation is normal after a reset (even when the idle is rough).
Just out of interest, why, when in closed loop mode, would the ECU need to store any data? - With adjustments being made at 'x' times per second, surely it could sort itself out regardless.
Even if you suddenly dump a load of fuel in with the emanage at idle, it'll sort itself out completely in around a second...
IMHO, the only time you should need to reset the ECU is if it has been spiked and acting irregular. - With all the things I've done with mine, I've never 'needed' to reset the ECU except to clear fault codes.
With a narrowband lamda sensor only to go on all it can do is guess the fuel adjustment, then wait and do it again. If it only had a single short term trim it would overshoot and takes ages to settle. With a long term trim it can use that in combination with the short term one to settle faster. Plus I think it might use it as a basis for cold start running too when there's no lamda signal to go on.
I am inclined to agree with that to, and exsperienced the quick re-trim of fuelling when changed by Emanage.
