remapping anyone !!!!!
thesword22
hi guys just wondering if anyone on here does remapping.
i have a import tt and its still running on the map from japan so so the fueling is all whacked lol so need to get it remapped i believe.
anywhos anyone on here do it and a rough guide price as well.
cheers in advance
hi guys cheers for the response
so far it is standard apart from a hks ssqv2 and a filter.
have toyed with the idea of putting the airbox back on or amking a replacement. will be having a custom straight through stainless exhaust (from the first cat back) made up very soon. will be 2.5 tubing.
You don't need to remap it. All thats needed is an ECU reset (disconnect battery for 2-3 minutes) and the ECU will adjust for the new fuel - which by the way should only be high octane like Optimax.
The ECU can adjust itself a surprising degree to cope with different petrol, but after 10 yrs of experience by members here there is absolutely no need to do anything to the ECU to cope for UK fuel. Just make sure you get a full tank of petrol to flush out any old stuff thats in there and do the reset mentioned above
i have the dynolicous software for the ipod touch
i dont know if it will be any help but i will go out and do a run with it and it will show the graph.
be back in a about 30
Don't bother mate, that won't show anything useful. Really need an AFR print or readings from your AFR gauge when we're talking about fueling.
Is it decatted?
