Warning triangle light
little num
You should get the triangle + "Slip control off" in writing, in light orange, in the clock fascia.
The dash lights can be dimmed manually via a control on the dash. See if you have it turned to minimum. :)
You should? I just get the orange notification light :search:
yeh simon only gets the TRC orange light as well, but mine was showing the triangle light but very dim, somthing wrong as i cant turn the dam thing off now (no fun with it on) need to take it out totally like homer said. lol
I'm sure you have checked it, but is your brake fluid right up to the full mark? Thats what caused the red triangle on mine now and again when I first bought mine.
