my Evolution VIII, massive spec !
lovatt
I am reluctantly putting up for sale my 2003 VIII due to the fact I’m moving abroad.
I have owned the car for around 4 years and it has had a small fortune spent on it! I fully intended to fit a large turbo setup on it but ran it on a very safe map and MR turbo for running in, it has only been run on an Mr turbo and the engine has covered around 5k miles and never missed a beat, even though its on a 10.5 turbo and safe map, you can see from the graphs it pulls like a train!
Due to this fact I future proof purchased everything on the engine, you can run a massive amount of power through this engine with a simple swap of the turbo, injectors and a remap.
The car is very tidy and valeted nearly every week by a professional valet company, the car is serviced more often than has been recommended and has never been involved in any accidents as far as I can see (and I should be able to tell as I am the manager of a very large body shop) the car has never been used on track since I have owned it and the previous owner told me the same as he used it as his company car. The car was 100% stock when I bought it.
The car can be sold with or without the private plate EVO 3 NUT and I am willing to take parts off to put stock parts back on or change the spec of the car within reason.
ENGINE
Evo 400 induction filter
Evo 400 maf deletion pipe
APS 3.5" full exhaust
HKS valve springs
HKS cam gears
HKS IC hard pipes
HKS cam belt
HKS 1.2mm head gasket
HKS 272/272 cams
HKS ssqv bov
Sard fpr
ARP head studs
ARP main studs
Crower con rods
Wiesco 85.5mm pistons (with Teflon coating)
Eagle billet crank
Megan racing exhaust manifold
THS ported turbo elbow
THS ally radiator
Exedy twin plate clutch
Walbro fuel pump
ACL chamfered bearings
3mm lash adjusters
MR Turbo with 10.5 turbo housing
Gems stand alone engine management
2 bar map sensor
Induction temp sensor
Up rated boost control solenoid
(Mapped by Steve Simpson)
Titanium valve spring retainers
Ralliart thermostat
Ralliart radiator cap
Balance shaft removal kit
NGK iridium spark plugs
Mocal 19 row oil cooler
Perrin Monster front mount intercooler
Samco coolant pipes
RC clear cam gear cover
On top of this I have had EVERYTHING stock such as gaskets, oil pump, water pump and loads of other things replaced with brand new genuine mitsi parts. The car has switchable anti lag but I have only used it a couple of times.
Here is the thread from when the engine was first built
http://lancerregister.com/showthread...ghlight=lovatt
CHASSIS
Alcon 6 pot front brakes
Goodridge brake lines
Motul RBF racing brake fluid
18" XT Visage wheels with Bridgestone Potensa tyres
XT fast road geometry setup
Eiback fast road suspension
INTERIOR, EXTERIOR
Privacy glass
Genuine FQ400 carbon electric mirrors
Genuine FQ400 carbon front splitter (half painted)
Genuine FQ400 fast road pads all round
MR front HID lights with orange blobs removed
Genuine MR carbon dash inserts
Genuine MR carbon exhaust surround
Half leather/ alcantara FQ330 seats & door cards
XT400 badges
ICE
Kenwood motorised flip out DVD, CD, TV, Radio, I cant remember the model but it was the best one you could buy at the time and cost me over 2k !
The car also has various amps expensive speakers
SECURITY
Tracker fitted
Clifford G5 (massive spec, to much to list Inc turbo timer)
Im looking for £16495, Take my engine spec price it up and you will realise what a bargain this is ! Anymore questions please PM me or call me on 07739394226
Ill try and take some better pictures as these are just some quick ones i took at work.
