Guest v8toyota Posted August 18, 2008 Share Posted August 18, 2008 need help!? n/a ecu has 2-40 pin connectors, while the tt ecu uses 3 connectors, where can i find the other 40 pin connector? its E10 plug on wiring diagram. if you can help let me know, thanks,jim Quote Link to comment Share on other sites More sharing options...
Homer Posted August 18, 2008 Share Posted August 18, 2008 You'll need to get the engine loom and ECU from a TT to do the swap. Apart from the harness itself they are not interchangeable. Quote Link to comment Share on other sites More sharing options...
Guest v8toyota Posted August 20, 2008 Share Posted August 20, 2008 I have the engine wiring harness,ecu,igntor,etc, but not that one E10 connector that goes to the tt ecu? what now?? Quote Link to comment Share on other sites More sharing options...
