Inconel EGT probes
Chris Wilson
3 mm diameter Inconel EGT probes. Probe only, needs terminating with the plug off your existing one. New high temp K type plugs and sockets available, to allow you to use these probes with any existing set up at 7.50 a pair. New stainless steel 3 mm inside diameter (for the above probes) 1/8 NPT male thread manifold adaptors also available. These are 12 pounds each, they will replace 90% of the probe adaptors currently in use. The probes themselves are 36 pounds each, plus £4.80 insured P&P. Inconel has a much higher temperature resilience than the cheapo ones that come in the Greddy and other common kits, and could mean the difference between a failure that takes your turbo with it, or trouble free usage. Electrically they are a direct replacement and your gauges will read the same. To order please E_MAIL me [email protected] I have 3 only of everything.
If we can get 4 more people wanting these I'll order a new batch. Otherwise they are now sold, thanks. If there's interest in adaptors to weld into thin wall tubular manifolds that don't have the thickness to tap safely I would consider making some stainless weld in adapters ready threaded with a 1/8 NPT thread.
Did you get my email chris?
  • 2 weeks later...
