How is Necessary For 550Hp 1994 Supra Turbo?
Stiffl3r
Hi, what is necessary to have 550-600 hp?
I have a Turbonetics Gt-66 single turbo with 6-1 Collettors, external westegate Turbonetics, HKS SSQV, inox manifold, Trust Intercooler Biggest Front, AEM ECU, gauges: turbo, air/fuel, oil temp and pressure, volt and exahust temp.
Clutch ok for 600 hp and flywheel fidanza.
Now i have a complete set of ergal pulley, fuel pressure regulator..
What i change for have about 600 HP? Without problem...
Edited by Stiffl3r (see edit history)
I'm guessing English isn't his first language. Mind you, he already speaks better English than I do Italian - plus he uses punctuation which is a breath of fresh air for a newbie on here these days.
I'm sure somoene will be along shortly to fill in the gaps of what is required for 600hp from a Turbo Supra, apart from what he has bought already.
I'd not be happy with the stock pressure cast pistons, I'd put some decent forged ones in it, preferably on steel rods, but certainly I'd put some decent rod bolts in the stock rods after having them re sized. it'll need cams to breathe well at that sort of output. Which cams depends on usage required, but 264 / 264 is the minimum.
If you want reliability on track you will have to make proper supports for the turbo and wastegate, just leaving them swinging on the tubular manifold will result in cracking. I'd want to know the material that these Turbonetics turbos use for the turbine housing. Genuine Garrett ones are Niresist, and don't crack or warp in external wastegate form. A lot of cheap turbos are just grey cast iron, and they do not like high temperatures and will warp and blow, or even crack.
Thank you for your help..
But nobody write the specific components list to install..
My turbo is very very good...
It depends how detailed you want us to go. At a high level you're only missing the injectors and fuel pump, but there's hundreds of other 'little' parts you'll need.
Can you give to me the list of these "little" parts?
I would like to have 600 Hp but during on time..
This is just an examplke (and was not ideal due to the poor choice of the XS power parts), but it does hit on a few key parts needed for any conversion. If you go with an aftermarket inlet manifold and fuel rail then there's quite a bit to add to it.
It was posted to illustrate the costs of a basic conversion (in the end it cost another £2k). There is another good thread in tech which I'll try and find now...
Here's the parts list for my turbo conversion (and this was a budget one!)
Engine components Cost
XS power kit £599.00
BL T67 dbb Turbo £900.00
AEM Air filter £40.00
BL oil kit £120.00
BL IC pipe £30.00
Blitz SBC ID-III BC £330.00
O2 flange £15.00
Nuts and bolts for T4 flange £10.00
PCV filter £12.00
Replacement water feed hose £9.92
4in silicon hose 120deg bend £52.95
M14 copper washer (x3) £0.39
1/2in braided hose (1m) £21.06
-10 hose finisher (x2) £11.70
1/4in braided hose (2m) £11.19
Steel tee piece 3/8in push on £5.29
Steel tee piece 3/16in push on (x3) £8.21
Hose support 0.25 ID (x4) £3.62
Hose support 0.44 ID (x4) £3.90
Hose support 1.13 ID £1.19
3/8in braided hose (2m) £13.42
Steel -8 x M14x1.5 adaptor (x2) £5.55
Alu -8 x M14x1.5 adaptor (x2) £6.42
Aeroquip 90deg -8 swivel (x3) £71.80
Exhaust Wrap (4m) £6.53
Aeroquip 90deg -4 swivel £17.77
Aeroquip -4/-3 adaptor £4.04
1/8nptf 90 deg fitting for 1/4in hose £3.29
Thinkauto postage costs £23.50
20mm Jubilee clips (x10) £6.00
Metal tie wraps free!
Fabric heat wrap free!
Exhaust Flexi pipe £50.00
3in-2.5in silicon adaptor £20.00
2.5in silicon pipe £20.00
HKS aluminium flange £25.00
Greddy 3 Row FMIC £900
Aeromotive FPR £120
Drivetrain
Kevlar clucth £450
Stock flywheel £250
Fitting £200
Fabrication costs
Manifold wastegate adaption £20.00
Downpipe adaptions (3 times!) £60.00
Filter intake cutting and filling £20.00
IC pipe flange & cutting £30.00
Screamer pipe adjustement £20.00
Adaptor Compressor housing £20.00
Fueling and ECU
Emanage Blue £150.00
Fields Harness £175.00
Connectors for EMB wiring £13.00
Power enterprise 800cc injectors £450.00
Mapping £300.00
Gauges
AFR Gauge £180
Greddy Boost gauge £120
Service items
Oil filter £7.38
10 litres Toyota Red coolant £30.50
Oil drain plug gasket £0.78
6 litres Silkone ProS 15w50 £55.00
Gasket paste £4.00
Other items
3inch 2nd decat £100
Boostlogic 4inch cat back £400
Total: £6552 (Not including labour)
This is witrhout touching the bottom end or head. If you're going for more than 600bhp (450-500ibft) then you should rebuild the bottom end, so an extra £4-5k
