supra matt Posted August 15, 2008 Share Posted August 15, 2008 Sorry to hear this Lui But by the sound of it Your egt probe is in one of the turbo's in the manifold And the tip of it has broken off the been blown through the turbo ! Hence No EGT reading and lots of smoke as it's Killed the turbo With the tip of the egt probe tip going through it . Link to comment Share on other sites More sharing options...
JamieP Posted August 15, 2008 Share Posted August 15, 2008 supra matt said: Sorry to hear this Lui But by the sound of it Your egt probe is in one of the turbo's in the manifold And the tip of it has broken off the been blown through the turbo ! Hence No EGT reading and lots of smoke as it's Killed the turbo With the tip of the egt probe tip going through it . My money is on that^ Link to comment Share on other sites More sharing options...
gaz1 Posted August 15, 2008 Share Posted August 15, 2008 JamieP said: My money is on that^ i agree same as mike B but his passed through the wastegate Link to comment Share on other sites More sharing options...
Scooter Posted August 15, 2008 Share Posted August 15, 2008 won't the blades have just been chipped bent etc.........not sure how this can result in oil leaking? Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 15, 2008 Share Posted August 15, 2008 supra matt said: Sorry to hear this Lui But by the sound of it Your egt probe is in one of the turbo's in the manifold And the tip of it has broken off the been blown through the turbo ! Hence No EGT reading and lots of smoke as it's Killed the turbo With the tip of the egt probe tip going through it . Sorry Matt don't think the sensor tip going through the exhaust turbine (metal) is going to kill the seals, make a bit of a mess of the turbine yes but not necessarily the seal. Link to comment Share on other sites More sharing options...
supra matt Posted August 15, 2008 Share Posted August 15, 2008 Tricky-Ricky said: Sorry Matt don't think the sensor tip going through the exhaust turbine (metal) is going to kill the seals, make a bit of a mess of the turbine yes but not necessarily the seal. It will if it got jammed the turbine or bent the shaft . Lui first thing to CHECK will be EGT probe Link to comment Share on other sites More sharing options...
Swampy442 Posted August 16, 2008 Share Posted August 16, 2008 (edited) You say it takes a minute or so for the smoke to appear from start up? Sounds like a turbo prob to me. When mine went I didnt have oil in the compressor side, just leaking past the turbine oil seal. Also as everyone else said it sounds really rough, the plugs will tell you something when you pull them. What is the engine oil level? Edited August 16, 2008 by Swampy442 (see edit history) Link to comment Share on other sites More sharing options...
Ian C Posted August 19, 2008 Share Posted August 19, 2008 If the turbo vanes are damaged, it'll be hugely unbalanced. Even a 'low' turbo speed is thousands of RPM so it'll oscillate and oval out the seals in short order, causing them to leak. Check plugs, check the first turbo as described already, physically unplug the WI hose from the throttle body. See what that lot gives you. I hope it's something simple and cheap to fix. -Ian Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted August 19, 2008 Share Posted August 19, 2008 sh*t! never nice to see... I thought leaking turbo seals caused a blue smoke? hope this is easy to sort out anyway mate. Link to comment Share on other sites More sharing options...
dandan Posted August 19, 2008 Share Posted August 19, 2008 Ian C said: ...........it'll oscillate and oval out the seals in short order, causing them to leak. Christ - I typed a long post and lost it all and can't be arsed to type it again........I hate it when that happens! The basics of it were on radial bearing clearances and how wear/misalignment would have to occur there first before any seals get subjected to whirling shaft dynamics beyond what they are designed for. Link to comment Share on other sites More sharing options...
Ian C Posted August 19, 2008 Share Posted August 19, 2008 dandan said: Christ - I typed a long post and lost it all and can't be arsed to type it again........I hate it when that happens! The basics of it were on radial bearing clearances and how wear/misalignment would have to occur there first before any seals get subjected to whirling shaft dynamics beyond what they are designed for. I got the explanation off Turbo Dynamics -Ian Link to comment Share on other sites More sharing options...
harley-jm Posted August 19, 2008 Share Posted August 19, 2008 bad news!! I had the same problem - although I paid the price for buying hybrids second hand ("only 1,000 miles on them guv, honest, Ive got the receipt" - which he then couldnt find when I had driven 100miles to collect them). I developed a massive smokey problem although they would only smoke at idle not under load - but the smoke was bad enough to be a danger to other traffic as no one could actually see where they were going!! It turned out to be a crack in the turbo housing. So basically I replaced the whole set up. At least your are still under warranty - would that include the considerable labour cost or replacing them? I think you should argue it should. cheers P Link to comment Share on other sites More sharing options...
supra_aero Posted August 20, 2008 Share Posted August 20, 2008 hope you get it sorted lui, my overheating problem, diagnosed by AA as a headgasket gone, turned out to be a thermostat so keep positive Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 20, 2008 Share Posted August 20, 2008 supra_aero said: hope you get it sorted lui, my overheating problem, diagnosed by AA as a headgasket gone, turned out to be a thermostat so keep positive The fact that the AA where able to diagnose a problem is surprising, getting it wrong is not:innocent: Link to comment Share on other sites More sharing options...
supra matt Posted August 20, 2008 Share Posted August 20, 2008 Any news Lui ? Link to comment Share on other sites More sharing options...
lui Posted August 20, 2008 Author Share Posted August 20, 2008 (edited) supra matt said: Any news Lui ? Not done any minor checks my self yet as not had time but might look next week, but now all booked in with James at Toyota Gt for Wednesday 3rd September to get all sorted out & I reckon No1 fault being my newly fitted with only 7000 miles on Envy Stage 3 Hybrid turbo's but will have to wait & see good job there still under warranty with Gaz at Envy. Just ashame if is turbo's as these are not cheap & with all perfect mods done to match did not think this would cause me problems at such low mileage with a full re-build & all mapped by Ian C for perfect set up. Edited August 20, 2008 by lui (see edit history) Link to comment Share on other sites More sharing options...
little num Posted August 20, 2008 Share Posted August 20, 2008 my first thought was turbo seals, it does look oily smoke. Link to comment Share on other sites More sharing options...
lui Posted September 3, 2008 Author Share Posted September 3, 2008 (edited) Mega low loader all booked in again now & down within the hour to be dropped off to ToyotaGT in good hands of James there to be fully diagnosed & get all sorted. I will be following it down there to make sure it has there perfect journey with no marks appearing while taking it off Hopefully nothing to major & will be all put right very soon :) Did not unfourntunalty have time to do minor checks myself but Toyota GT will do all necessary checks needed to be carried out. Edited September 3, 2008 by lui (see edit history) Link to comment Share on other sites More sharing options...
tDR Posted September 3, 2008 Share Posted September 3, 2008 Have to say looks a lot like my SX when the turbo blew it's oil seals. The fact you have no EGT reading ties up with the probe breaking off, going through the turbo and causing it to be unbalanced which then leads to vanes touching the housing (mine was practically hanging off the shaft to one side) and the seals leaking - that gives the Batmobile mobile smokescreen effect! The worry here is always whether there's engine damage as a result - get a compression test done whilst it's at Toyota GT. Cheers, Brian. Link to comment Share on other sites More sharing options...
MarkR Posted September 3, 2008 Share Posted September 3, 2008 Sorry to hear this Lui. Hope it gets sorted soon. Link to comment Share on other sites More sharing options...
lui Posted September 3, 2008 Author Share Posted September 3, 2008 TyranoSupraRex said: Sorry to hear this Lui. Hope it gets sorted soon. cheers bud hopefully nothing to bad still waiting for relay should be within the hour then it's off to hospital to get sorted Link to comment Share on other sites More sharing options...
MarkR Posted September 3, 2008 Share Posted September 3, 2008 lui said: cheers bud hopefully nothing to bad still waiting for relay should be within the hour then it's off to hospital to get sorted It just goes to show that you can do everything right, spare no expense, get what could be termed as a very safe and protected build and still have a patch of bad luck. I'm sure you'll agree that the worst part is all the hassle of getting it sorted afterwards, taking it to garages, fault finding etc. Painful! Link to comment Share on other sites More sharing options...
lui Posted September 3, 2008 Author Share Posted September 3, 2008 TyranoSupraRex said: It just goes to show that you can do everything right, spare no expense, get what could be termed as a very safe and protected build and still have a patch of bad luck. I'm sure you'll agree that the worst part is all the hassle of getting it sorted afterwards, taking it to garages, fault finding etc. Painful! Still putting my money on to do something with turbo side of things & hopefully not damaged anything else Link to comment Share on other sites More sharing options...
lui Posted September 3, 2008 Author Share Posted September 3, 2008 (edited) On tow truck now & setting of to Toyota GT wish us luck http://img237.imageshack.us/img237/2927/img1582tg1.jpg http://img237.imageshack.us/img237/img1582tg1.jpg/1/w800.png Edited September 3, 2008 by lui (see edit history) Link to comment Share on other sites More sharing options...
MarkR Posted September 3, 2008 Share Posted September 3, 2008 Good luck! Link to comment Share on other sites More sharing options...
