No second turbo, But only during first gear
miko_supra
  • Replies 52
Well, test successfully carried out, floor it in 1st, trac control off, redline........peak boost seen as 1.18. Both tubbys are coming on for sure......1st gear is savage :D
lucky sod :) , I will check my readings but I know its not coming on it used to spin up in first I can feel and hear theres naff all at the moment
No not the problem, but what boost readings at what rpm are you seeing when you are having the problem.
I get about 0.7-0.8 bar in first gear, if I push it with the TC off, it does seem to come in but later in the rev-range than normal. Seems to be a lot of people experiencing the same issue.
I will give that a go aswell ,does anyone else get this ...for example if I am in fourth give it some beans to so it builds up 1.2bar but not hold it flat out in 4 but change into 5th early then the exhaust note changes for around 3 seconds where there is no boost while something happens then I can hear the turbo spool again is this normal even if I keep my foot on the acc in the same place ? hard to explain really
If you're not getting the second turbo running in then may be worth giving the Iacv valve a bit of a clean up, also giving the egbv a clean whilst you're at it :) The egbv is the most likely cause
I had this until I fitted my Greedy boost controller. I can therefore only surmise that it was the VSV?
Yeah, or at least the one at the front of the engine. I'm not very good with knowledge on the numerous valves and actuators on the turbo system but this worked for me.
Thanks I will give it a go , problem is I have a 1.2bar r-ring so my ebc I have not plugged it in but I guess if I plug it in and leave it set to off it will still bypass the vsv for me
  • 2 months later...
Further to this thread, mine has started doing it since having hybrids fitted. Someone else mentioned it doing it after fitting a fmic. I reckon a change in induction system may benefit an ecu reset. Ill do it tonight and report back.
I tried that , it did not work hope it does for you though
ex toyota technician here.
It is to prevent major wheelspin. this is a standard trait on supra's not to pull to hard below 10mph or something
cant remember my training all to well but i think thats about right :p
Sure? Is there a way round that? :)
lmao no there is no way. toyota emtec dont train technicians on mods XD
hence why you find me asking about things like bov's in other threads.
this thing is ecu jobby. u cant really get rid of it, and to be honest i wouldnt know where to start. an answer is possible with research.
i imagine top secret know that answer XD
