brand new supra engine
TRD DAN
  • Replies 54
ive decided to buy it just rang the guy now
:blink: Unless you are getting it for silly cheap as it is knocked off or the guys knows it is fecked and is a reject.
Would £14k not stretch getting an old engine rebuilt replacing everything with either new OEM parts or uprated parts, get the block sand blasted to make it look like new?
A full engine rebuild with some nice uprated parts and a brand new block from Toyota would be a lot less that £14K
oh deffinateley , but this is brand new everything , if you priced that all up its not far off £14k all sensors loom everything
In that case I would be calling to cancel, I would rather have a slightly uprated one, more money than sense if you ask me. ;)
if you scroll down you will see a fully built stroker engine for 14K, but that is in Dollars, know which one I would go for ;)
add $2K for a brand new short block, as above with your old block, still less than £9,000
http://www.mvpmotorsports.com/Templates/frmTemplateM7.asp?SubFolderID=4074&SearchYN=N
