Mike B Posted August 13, 2008 Share Posted August 13, 2008 Has anyone had any and success in using sealant to seal the oil feeds on single turbos. Mine uses an alloy fitting and I'm not wanting to really tighten it up to hard as I have stripped threads before.. and it's no fun! any sealant suggestions greatfully received, Quote Link to comment Share on other sites More sharing options...
uk-rich Posted August 13, 2008 Share Posted August 13, 2008 (edited) i once used some stuff called curil t, very good, designed for gas turbines if its a taper thread, you do not need any Edited August 13, 2008 by uk-rich (see edit history) Quote Link to comment Share on other sites More sharing options...
Mike B Posted August 13, 2008 Author Share Posted August 13, 2008 (edited) thanks bud, that looks like it will do the trick nicely. ps, do you really make bra's and corsets for a living? powered by a Kai T51, and ladies underwear... result! Edited August 13, 2008 by Mike B (see edit history) Quote Link to comment Share on other sites More sharing options...
SteveR Posted August 13, 2008 Share Posted August 13, 2008 (edited) subscribed - my feed keeps loosening & weeping, depite being new and regularly tightened up. Edited August 13, 2008 by SteveR (see edit history) Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 13, 2008 Share Posted August 13, 2008 I just use good old Loctite 243, works for me. Quote Link to comment Share on other sites More sharing options...
johnd-mkiv Posted August 13, 2008 Share Posted August 13, 2008 I used red hermatight on mine the oil drain was leaking aswell so i welded the aeroquip joints up then put it back together, no more leaks Quote Link to comment Share on other sites More sharing options...
uk-rich Posted August 17, 2008 Share Posted August 17, 2008 thanks bud, that looks like it will do the trick nicely. ps, do you really make bra's and corsets for a living? powered by a Kai T51, and ladies underwear... result! my missus runs the business, but i get to "vet" all the products Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 18, 2008 Share Posted August 18, 2008 Loctite Hydraulic Seal or a few wraps of PTFE tape, Loctite is best you don't really want the risk of bits of tape in the oil system. Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted August 18, 2008 Share Posted August 18, 2008 I just use good old Loctite 243, works for me. ditto:) Quote Link to comment Share on other sites More sharing options...
jacko Posted August 18, 2008 Share Posted August 18, 2008 ye loctite bush retainer works well Quote Link to comment Share on other sites More sharing options...
