SilverSoop Posted August 12, 2008 Share Posted August 12, 2008 Hi all, i know this maybe a repost but i was shocked a what i found on the HKS induction filter. I took it apart and off from the intake pipe and found gritty deposits that found themselves INSIDE the air filter and INSIDE my intake pipe! I just hope this hasn't done damage to my internal components! Luckily, i have got a major service coming up in the next couple of weeks so i willl be changing it do an Apexi induction filter... I did do a bit of modification to the the HKS filter though, i unscrewed the screw which connects the filter to the cone, put a washer on the plastic cone, crimped the metal cage like stuff which goes over the foam element and put it back together and i found that it now connects together tighter and wont let particulates find their way into the filter from the back as it was before and also seems more of a stable filter (not like it was before) I know the problem is far from cured but will help anyway. The reason i put the washer on the cone is because i can see through the filter! Hopefully by doing what i did, will stop some crap being sucked through the middle of the filter... Don't buy an HKS filter! They are rubbish! Quote Link to comment Share on other sites More sharing options...
AndyT Posted August 13, 2008 Share Posted August 13, 2008 Yep. I think Blitz, TRD, and stock are the top rated items of choice. Bleedin' smileys aren't working. Tut. Quote Link to comment Share on other sites More sharing options...
Max Headroom Posted August 13, 2008 Share Posted August 13, 2008 http://www.mkiv.com/techarticles/filters_test/2/ HTH Quote Link to comment Share on other sites More sharing options...
Alex Posted August 13, 2008 Share Posted August 13, 2008 I don't agree on the Blitz either...it's a metal mesh not cotton or paper. K&N or Apex'i are the only aftermarket filters I would use as they are cotton. But the stock one is the best for filtration period as it's paper. Quote Link to comment Share on other sites More sharing options...
SilverSoop Posted August 13, 2008 Author Share Posted August 13, 2008 http://www.mkiv.com/techarticles/filters_test/2/ HTH Haha, HKS's statement is load of crap! That exactly what the Filter DIDNT do! Quote Link to comment Share on other sites More sharing options...
SilverSoop Posted August 13, 2008 Author Share Posted August 13, 2008 I don't agree on the Blitz either...it's a metal mesh not cotton or paper. K&N or Apex'i are the only aftermarket filters I would use as they are cotton. But the stock one is the best for filtration period as it's paper. Im definetely going to go with Apexi... Quote Link to comment Share on other sites More sharing options...
SilverSoop Posted August 13, 2008 Author Share Posted August 13, 2008 Yep. I think Blitz, TRD, and stock are the top rated items of choice. Bleedin' smileys aren't working. Tut. Yeh tell me about it, mine aren't either :-( Quote Link to comment Share on other sites More sharing options...
SupraShaun Posted August 13, 2008 Share Posted August 13, 2008 Does anybody know the size of neck of the HKS filter? Mine came on the car and after seeing the review Max Headroom linked to i better get it off! Quote Link to comment Share on other sites More sharing options...
Nic Posted August 13, 2008 Share Posted August 13, 2008 Im definetely going to go with Apexi... If you need price for one just let me know. Quote Link to comment Share on other sites More sharing options...
SilverSoop Posted August 13, 2008 Author Share Posted August 13, 2008 If you need price for one just let me know. Yeh please Nic, how much do you charge for the Apexi filter?? Quote Link to comment Share on other sites More sharing options...
bolarbag Posted August 13, 2008 Share Posted August 13, 2008 HKS are absolute rubbish, it puts me off most of the main Jap suppliers when they ship out utter boll^^ like this It depends on how long the filter has been on there, best to do a compression test to find out, but the IC should give you a slight helping hand in filtration, if you really do care about your engine though and expect to keep the car for a long length of time you cannot beat paper I've never understood the concept of oiled filters, how is air meant to pass through oil? They increase airflow by using foam, then take it away using 'oil', which no doubt gets sucked in to your intake anyway Quote Link to comment Share on other sites More sharing options...
SilverSoop Posted August 13, 2008 Author Share Posted August 13, 2008 HKS are absolute rubbish, it puts me off most of the main Jap suppliers when they ship out utter boll^^ like this It depends on how long the filter has been on there, best to do a compression test to find out, but the IC should give you a slight helping hand in filtration, if you really do care about your engine though and expect to keep the car for a long length of time you cannot beat paper I've never understood the concept of oiled filters, how is air meant to pass through oil? They increase airflow by using foam, then take it away using 'oil', which no doubt gets sucked in to your intake anyway Exactly, when i saw particulates in my intake system, i was shocked, i could physically take the grit out! Im getting rid of it ASAP! Quote Link to comment Share on other sites More sharing options...
