Guest lukesupra Posted August 12, 2008 Share Posted August 12, 2008 hi guys had a problem for a while and its got worse now, everytime i change gear or at low revs turn a corner or anything really i have the master warning light (like the 1 where the handbrakes on) but when i put my foot down it goes off then when i change gear its back on again!! any1 have any ideas?? it aint brake fluid? Quote Link to comment Share on other sites More sharing options...
hadyn Posted August 12, 2008 Share Posted August 12, 2008 Yep its the brake fluid warning light. Quote Link to comment Share on other sites More sharing options...
Guest lukesupra Posted August 12, 2008 Share Posted August 12, 2008 didnt mean to put a question mark sorry it isnt brake fluid its recently been topped up Quote Link to comment Share on other sites More sharing options...
hadyn Posted August 12, 2008 Share Posted August 12, 2008 Sometimes when your brake pads wear out, the cylinder in the calipher pushes in due to the lack of pad, eating up fluid causing the brake fluid to run low. Also when accelerating/cornering hard the brake fluid in the reservoir flies all over the pot which causes the sensor to throw up a warning light. If its the main triangle warning light and the (!) light you see when you usually have the handbrake on, I'm 90% sure its brake fluid Quote Link to comment Share on other sites More sharing options...
Ric Posted August 12, 2008 Share Posted August 12, 2008 didnt mean to put a question mark sorry it isnt brake fluid its recently been topped up top it up more, we arnt wrong about this one Quote Link to comment Share on other sites More sharing options...
Guest lukesupra Posted August 12, 2008 Share Posted August 12, 2008 ive just checked on sat its defo not brake fluid could it be a wiring fault? Quote Link to comment Share on other sites More sharing options...
SimonB Posted August 12, 2008 Share Posted August 12, 2008 ive just checked on sat its defo not brake fluid could it be a wiring fault? No, it's your brake fluid. Top it up even if it looks like it's above the line. One of the most common "faults". Quote Link to comment Share on other sites More sharing options...
Guest lukesupra Posted August 14, 2008 Share Posted August 14, 2008 well found out the callipers seized on and its just started making a horrendus noise over me exhaust lol, its in the garage getting freed 2mora! hopefully it wont seizde again after! Quote Link to comment Share on other sites More sharing options...
