Guest jokkan Posted August 12, 2008 Share Posted August 12, 2008 Hello, I got a big problem. When I reach 2000rpm, my supra begins to stumble, ( hack or whatever word that fits in, I guess you get the picture) when I reach 2000rpm. If I try to speed up even more when it starts to stumble, the speed wont increase. My enginelamp shows code 13: http://www.mkivsupra.net/vbb/attachment.php?attachmentid=13920&d=1112558346 Anyone have a clue? I have changed crankshaft sensor, ECU and I know my camshaft postion sensors works! /jokkan Quote Link to comment Share on other sites More sharing options...
spartan Posted August 12, 2008 Share Posted August 12, 2008 (edited) Have you checked the condition of your timing belt, tensioner and crank/cam pulleys? Edited August 12, 2008 by spartan (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest jokkan Posted August 12, 2008 Share Posted August 12, 2008 My timing belt is new and crank/cam pulleys works. I forgot to write that my engine is newly built! Quote Link to comment Share on other sites More sharing options...
spartan Posted August 12, 2008 Share Posted August 12, 2008 OK. If you're happy with all the components and sensors (and assuming the cams have been timed-up properly) then perhaps there is a problem with the wiring somewhere between the engine and ECU. Can you check for signals or even just continuity? Quote Link to comment Share on other sites More sharing options...
bignum Posted August 12, 2008 Share Posted August 12, 2008 is your car j-spec or export model? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 12, 2008 Share Posted August 12, 2008 I would suspect the star wheel (the crank trigger disc) is loose on the back of the cam belt pulley, it was probably damaged when the engine was rebuilt. it's easily done. I stitch weld them on when I do an engine build. If the code is to be believed, the crank position sensor is new, and the wiring, connectors and plugs at both sensor and ecu end are perfect I think I would look there. Quote Link to comment Share on other sites More sharing options...
spartan Posted August 12, 2008 Share Posted August 12, 2008 (edited) This? Edited August 12, 2008 by spartan Bad English! (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 12, 2008 Share Posted August 12, 2008 Yes, (and BTW, I will answer your e-mail this evening), the star wheel can come off the back of the cogged crank belt cam wheel, and it's not an uncommon problem. The disc to the right is just a belt guide and has no effect on the ecu sensor. Quote Link to comment Share on other sites More sharing options...
Guest jokkan Posted August 12, 2008 Share Posted August 12, 2008 Thanks for the advise about the star wheel. I will check it tomorrow. My car is -94 J-spec! Quote Link to comment Share on other sites More sharing options...
